DIY Turntable RCA Cable
Thank you so much MR. Duane,
Reactions: MisterDK
Just a personal oppinion:
The mentioned cable has a "staku" inner conductor. This is steel with a copper layer on top. Noting I would use in HIFI. MHz high frequency doesn't care for the high Ohm resistance of steel, very low voltage audio signals do. Never use it for a record player / pre-amp connection. You probaply picked the wrong product from the REICHELT side.
Many years ago, when computers used ethernet cards (anyone remember Novel Netware?) with coaxial cable and networks became common even in private or small enterprises, these where made in high quality. You could get silver plated inner multi strand copper conductor, aluminum foil shield plus a 100% cover of silver plated, woven copper shielding, covered with soft, high flexible plastic for ridiculous low price, if you took 50 or 100 meter of it. I used mayn spools of this stuff for car audio, active multi amp installations and for home HIFI. It lasted for ever, one of my (now!) vintage car installations is 30 years old and still 100% fine. Today you have to search for such quality, as cheap, steel (STAKU) and aluminum outer shield have taken over. Often you can't even solder the shield!
The same goes for antenna coax cable. Most low priced products use steel conductors inside.
So now include "wire" in the Vintage and NOS category. Sometimes I laugh at myself "Why do I have bins with just old wires in them?" The old defunct, unrepairable HiFi equipment yields a harvest of the "good" stuff. How many such items I let skip through my hands, full of at least "wire".
Not many consumer grade devices have excellent wiring either so another reason must be made up to defend having piles of stuff 😉
Truth be told, quite often I have wiring of the not so old kind already having sticky isolation (disintegration). The very old kind usually is still OK. Probably the greener stuff is the shorter it lives.
