You are right Andy, the mechanical force from the cone moving transfering to the cabinet would be a significant contributor to exciting modes. Probably way more than air pressure. Thanks! At this point i don't know how to include that in the modeling.
My original idea was to run a steady state modal dynamic with an equivalent pressure on the walls, but this won't take what you mentioned into account. I just finished a class on Abaqus, but will have access to running simulations remotely for another year. This topic was not covered in the class, so im learning as i go.
The reaction to the accelerating mass of cone assembly plus air is a body force within the magnet. The size of the force is mass times acceleration. The acceleration follows from a simple lumped model of the driver. The mass of the air is given by the reactive part of the air impedance which is likely to be fairly constant and modelled fairly well by that of a piston in an infinite baffle though a more sophisticated model should be easy enough. If your software doesn't support body forces within the elements of the magnet then apply an equivalent pressure to the back of the magnet in the way you are doing for the air pressure on the inside of the cabinet. The magnet is going to move effectively as a solid body so it will have the same effect.
I have never seen any test with identicaly sized enclosures, braced and without any bracing, maybe different materials or thickness with logical measurements. This would have been not that expensive, if someone really wanted it.
Here's a goldmine: https://www.avsforum.com/threads/a-monster-construction-methods-shootout-thread.3154560/page-4
Andy: I will try a coupled acoustic-structural model instead. Thank you for the input!
As a general statement that might be unwise. Consider a subwoofer in a relatively light cabinet that moves around on the floor when playing loudly. Would decoupling be a better solution than placing something heavy on top of it or adding grippy feet?
There are a number of physical processes involved with loudspeaker drivers in a cabinet in a room and whether passive isolation is beneficial, harmful or irrelevant will depend on the masses, stiffnesses and damping involved.
Thats a cabinet problem.
Coupling the structural motion and the acoustics is complex and unecessary. The load of the air on the cabinet is weak and pretty well modelled with an impedance. Simulate the cabinet structure with relevant boundary conditions applied for the external forces and then simulate the external acoustic field with an acoustic BEM or FEM software using the calculated motion of the cabinet as velocity boundary conditions. If keen one could recalculate the motion of the structure using the calculated surface air pressure rather than the originally assumed ones but it almost certainly won't make a big enough change to be worthwhile. Might be worth doing once as a check though.
It has drawn this typical response from you avoiding the topic being discussed, let readers know that your pontificating is not based on scientfic/technical reasoning (or at least suggested it for those that lack the technical knowledge to see it directly) and indicated how they might go about resolving matters for themselves using what they were taught at school. I would hope that was a useful rather than silly contribution to the thread.
I expected better from this discussion than the same blather we read from deluded audiophiles who favor magic over proven science. So until you someone here posts actual data - as I have done - I having nothing further to add.
Should be obvious.
Air movement — half the energy goes into the box and the other half is radiated out into the air. Furthermore air is not a great conductor of mechanical energy. Not to mention any fibrous damping material.
Direct connection to the box via the baffle: ALL the energy goes into the "box + baket".
dave
I believe i posted this from a study (publihed in the AES Journal) earlier:
Wasnposted here: https://www.diyaudio.com/community/threads/bracing-vs-damping.428225/post-8024367
dave
It's a little more complicated than that because it varies with frequency. At LFs the box is very rigid and is just another mass to the drivers frame, not so at all at frequencies where the box has mechanical resonances. AT LFs the air in the box pressurizes the box with a uniform pressure throughout creating a breathing mode (monopole) which is an extremely efficient radiator. So it's clearly different with frequency.Direct connection to the box via the baffle: ALL the energy goes into the "box + baket".
The fundamental question of this thread was about isolating the driver from the box. That is absolutely the wrong thing to do. An isolated driver has to be on springs. The drivers mass and this spring will resonate. When this happens all the energy will go into the moving the drivers mass and there will be a big hole in the response.
If you are calling the demonstration that you showed as "data" it is seriously flawed in so many ways. i.e. if the displacement of the glass is normal to the water surface then the surface will show nothing. And this is precisely the direction of motion that we are most interested in. Then there is the signal and the "meter" (our eyes!?) In other words, your "data" is not worth considering. There is lots of data that cabinet walls vibrate. Is it significant? I do not and have never considered radiation of the box as a major concern. It is on my list, just pretty far down. Only in a superb loudspeaker would this ever become an audible issue (assuming of course that the speaker is not blatantly poorly designed.)I expected better from this discussion than the same blather we read from deluded audiophiles who favor magic over proven science. So until you someone here posts actual data - as I have done - I having nothing further to add.
As far as I can tell, I'm the only person here who has actually tested this stuff. I see a lot of speculation, and comments like "We've known this for a long time," but no actual data. While you work out your plans to devises a suitable test to post here, this video is yet more evidence that common competent speaker cabinets do not vibrate and thus have nothing Ito transfer to the surface they rest on:
Isn't that a dual opposed sub? If so, I think that should be mentioned.
If not, how much does that dang sub weigh not to vibrate ? 🙂
It is. But everything varies with frequency.
Ballooning cn be a probelm with a subWoofer. But SubWoofers can be treated differently. Build light and stiff and take advantage of active push-push reaction force cancellation and once sufficiely braced ballooning becomes quite unlikely.
dave
If you are calling the demonstration that you showed as "data" it is seriously flawed in so many ways. i.e. if the displacement of the glass is normal to the water surface ...
No, the article I posted originally with actual room measurements showing no difference between isolation and no isolation. Here it is again:
http://ethanwiner.com/speaker_isolation.htm
Ethan, i see nothing there that tells us anything about the DDR. Isolation/decoupling would show up first in the small details.
dave
dave
What is DDR? And why do you think my very carefully controlled tests are not proof that decouping makes no difference? Please be very specific.
DDR = Downward Dynamic Range. A term coined by Allen Wright. A giant in the field. A term to describe all the small stuff still there even in the face of a big signal.
This analogy may help: The FR measurements we take are a measure of the surface of a body of water (mirror smooth is the target). DDR measures the depth of the water (deeper the better). This is one of the significant reasons a loudspeaker with a rough “surface” can “outperform” is that it is has "greater depth” — better DDR.
A system with good DDR will have all of the small details that give voices body and make them distinct, differences in instruments, and a good solid 3D soundstage/image. The difference between a good system and a great onne.It still eldes being quantified. Why Floyd Toole said:
Of course this information has to be on the software being played, and that the signal chain, loudspeakers and how they interact with a room need to lose as little of this information as possible. That is the whole job of a hifi system.
Collums recently wrote a bit:
So despite the fallibility and plasticity of the ear/brain hearing system it is still how we have to do “final” evaluation of the system. And given the large number of degrees of freedom that means alot ofpeople happy with a lotofdifferent hifis.
dave
Two ears and a brain are massively more analytical and adaptable than an omnidirectional microphone and an analyzer.
it is a matter of optimizing the transmission of the more subtle information that describes recorded acoustic, instrumental detail, the performers, and, not least, dynamics and rhythm: Are your feet tapping unconsciously in time to the performance?
dave
- What's the problem with modern proper loudspeaker cabinets decoupling?
