The First Watt is The Sweetest!
First Watt my way.
Actually puts out 2 Watt with acceptable distortion.
But not much more. Depends on the supply voltage which is 20 Volt single end.
EF2 has a larger crossover region, period. Unless first stage of it stays in class A. Also robs 2 Vbe. When those two vbe are a significant fraction of the supply voltage, you may not want to part with them. Running off 6-12 volts, EF1 is the way to go unless you are trying to drive 2 ohms or something. Unless you can find a nice pair of Ge’s and can make or find a totem pole driver transformer. I had a number of old car radios that did that - and they played cleaner than any modern (non-high-power) ones using those stupid chiplifiers. I mentioned I found a way to make those sound good, but damn it generates heat.
Reactions: lineup and banat
This true, but don't exaggerate it.
The it is not a problem to keep the first stage of EF2 in class A. With a proper VBE multiplier, the output impedance of the first stage could be way lower than the input impedance of the output stage. Crossover region won't be affected that much.
Reactions: lineup
EL38? 40 wpc? That's a really nice amp.... nice cooling slots in the front panel
PP EL84 triode running class A driven by an ECC81 LTP. All poly caps including the PS. Based/inspired by Eli’s El Cheapo
Based on chassis and iron from a Scott LK48/222. Once stripped the holes are left.
dave
First Watt my way.
Oh It look almost same my amp.
first I build up JLH amp . after 02 days have reason amp so hot & it using alot of power waste . I modify it as same this circuits then i can adj bias to get litter bit class A then feel it better than original JLH amp.
Reactions: lineup and alain98
Say we have speaker pair with sensitivity SPL of 90dB per Watt.
Then 1 Watt will give soundpressure 90dB at 1 meter.
As there are 2 speakers the SPL will be 93dB at 1 meter.
But you listen at a distance of 3-5 meter, so the SPL at listening position will be less.
Anyway, you come a long way with only First 1 Watt.
