Best electrolytic capacitors
The basic parts should be good.
What I would look at is where they are in circuit, the operating voltage and what those are rated for. Just because it is a new build and design doesn't mean they were used properly. Maybe just old habits from service work, but I still put much higher voltage rated solid tantalum capacitors in than you would for an electrolytic. They will not tolerate voltage spikes or reverse polarity.
Reactions: Franz Shottky
Exactly as described. Check to verify. Usually there is a brand symbol, a value and voltage and a datecode. Still logic says these are not the famous bad tantalum caps of decades ago. These have a reputation so bad that current tantalum caps still suffer and about every designer is familiar with the matter.
I know you think I am retarded but the point is I think it is completely logical to check such trivial things when looking at a board and the parts.
The bag you show has no labels. I would discard those if there can not be determined what brand/series and age they have.
Soon ill be replacing electrolytic caps on the boards of a Philips CD303 I recently picked up. It probably recently had its 40th birthday - hope the previous owner organized a nice getogether to celebrate. At least they didn't mess with it, as it looks almost factory original. Great sound too. It sounds like I'll be retiring my TDA1541A-based DAC and go back to spinning discs.
Choosing caps for obsolete series of 'lytic caps is a bit tricky given the ridiculous of number of products available. I try to stay as close as possible on all specs, from physical dimensions and form factor to electrical specs down to esr. For example, it's nice that the many 22uF and 33uF axial ones appear to have replacements in current production Vishay BC components.
I wonder about 'low leakage' specs tho. For some 2200uF and 1500uF smoothing caps on the power supply board (right after the diode bridges), the caps that match the original most closely (except for the leakage current spec, as the originals were quite leaky according to an old Philips data book) are Nichicon UKLs. Is there any reason not to use UKLs there?
I always considered low leakage electrolytic caps as something exotic and use them where explicitly called for (like in the feedback network of an opamp based discrete series voltage regulator that I use a lot - I will be stocking up as they're being phased out).
But shouldn't every cap be 'low leakage' in principle? Who would want a leaky cap anywhere? What's a cap that's not 'low leakage' anyway? Pretty leaky, medium leaky, super leaky? I reckon that most of the time marketing departments don't ask themselves that question.
Hi kunlun121,
Honestly, Electrolytic capacitors are non-critical despite what people say. Each cap varies widely in the same batch for example. ESR may matter for power supply filters, but if this is critical they would use high frequency types. Not common when this was built.
My strong advice? Buy good quality capacitors from authorized distributors. The larger case will be a better part, don't put one in too large. Higher voltage ratings are generally better and help to have the same size case. These capacitors will not change the sound. Others will, but not many here talk about what actually does matter.
I've been a paid technician for almost 50 years, servicing longer. Studied parts since I began, and I have the equipment to do it. Serviced real high end audio and recording studio equipment. I'm just trying to save you effort and money while suggesting the best outcome for you. What you do is totally up to you. For many, parts are a religion based entirely on beliefs and anecdotal reports without real testing. "White papers" are just advertising copy with some technical stuff thrown in that often isn't applicable or truthful (it's an ad, remember?).
I'll say it one more time. There is no best make / model of capacitor. Each part has characteristics that make it better for one circuit location over others, and production tolerance makes the difference between good brands and models insignificant. ESR has no bearing in coupling applications, except in series with a load (higher current). What differences matter even at one ohm when the circuit impedance may be over 1,000 ohms? This is the extreme example in favor of ESR. What can matter more is dielectric absorption. But only when you generate a signal voltage across the capacitor. By definition this doesn't happen with coupling capacitors.
I've serviced CD players since they were introduced. Trained at Philips and other manufacturers.
