How? I mean, for what it offers it seems quite pricey and the connectivity reviews are mixed.
BTW, I found the WiiM Ultra on Sale here:
https://www.kingsleymall.com/produc...ping&msclkid=180fb926aadc1e2ba383d1257c4fa481
But I've never heard of them and the price might just be too good to for real?
In any event, the way it looks like now is that the WiiM Ultra with a nice DAC... for around 1000 bucks, is a very good sounding proposition. If you look around and can find used and sale items you can walk away nice.... I got the Topping D90LE for 400 bucks... I'm into the Burson Swing with the v7 Classics for 550 bucks and the Nitsch I paid full MSRP. I also got the RME AD/DA FS but, even when I bought it almost brand new used, was still a LOT more.
There are some glitches still using the Ultra from Tidal Connect from a PC... it fails to appear as a device... so I got to toggle the DNS server setting over WiiM Home application... I see the same both on WiFi and Ethernet. This weekend I'll try using static IP addresses over Ethernet, see what happens.
It is indeed a device made for Android devices!
Great price on the Ultra an KM but I did a quick search for reviews and not so great to deal with, buyer beware might be the way to go there.
RIck
RIck
Yeah... thanks... I am having a great time with this little box. I forgot what I was missing when I took out the PC from the main rig and lost bit perfect playback.
Gulp.... I keep thinking that I might have to do a re-thinking of my audiophile priorities...
Hmm.... like perhaps I should simplify my life.... listen to music.... get rid of the three racks, SELL some of the stuff, no need for a stereo in every room... get rid of the hardware habit... Who needs two pairs of Magnepans when one pair has been in the box for five years.... all those amps... all those records...
NAWWWWWWWW
I need another WiiM Ultra for the wife's home office. My daughter might need one too... but WAIT, she's got an iPhone... hmm....
NAWWWWWWWW
For those of us who normally have to get up to change the volume on their pre or power amp, it can be done without the sound degrading volume slider.
I found that the pre gain sliders going from -10 to +10db do not degrade the sound.
For me that's plenty db to find my sweet spot of loudness between different tracks and even different inputs.
Most convenient when using Tidal or any other streaming service as the pre gain tap can be left open. Less convenient though if listening to music via the Wiim app library as you have to go to the pre gain tap leaving the library to adjust the volume.
Klaus
Klaus
Came across this and wonder what it is about. Jitter as measured by Amir is absolutely fine even if not stellar.
Just curious, does the USB output contain a sub out channel or is it just the main channels with or without HP? Is there a digital volume control on any of the digital outputs or is volume control relegated to the DAC or amp?
Got the same SMSL DDC and an even better Fifo DDC from Ali.
They make a noticeable difference in clarity and spacial presentation.
The volume disable works both for USB and the built in DAC. That also disables room correction.
INTERESTING BEHAVIOR.... When playing over USB to an external DAC. With fixed volume.
You can not modify the volume with the remote... BUT you can change the volume when using WiiM Home!
Check this out... the volume is set to fixed... yet with WiiM Home I can drag the volume limit bar.
BTW, the connection to the DAC doesn't like that... at least the Burson Swing DAC. When I do mess around with the volume this way, while playing Tidal Connect, sometimes I have to cycle the power of the DAC to reset the connection between the WiiM and the DAC.
BTW, when I was showing my wife how to use the WiiM Home in the stereo, while she was using her Android phone to drive it with Tidal HiFi.
She asked how to change the volume?
For a second I was miffed... then I realized..
The volume control on the preamp.
I mean, what's wrong with using the volume control knob on the front panel of the preamp?
BTW- The Nitchsch DAC with the Schiit USB Multibit / Unison interface doesn't need those USB reclockers. Indeed, the sound of that unit when hooked up to the WiiM is better than my other DACs. In fact, I'm looking at getting rid of the other DACs and buying some of Schiit DACs with balanced outputs.
The clarity/purity of the treble is outstanding.
What is your set up like?
I think the DAC's USB makes a huge difference.
Once again, I think Schiit's stuff doesn't need the USB reclocking at all.
Mike Moffat designs the Schiit digital stuff... and I honestly don't think his USB DAC can be bettered. The WiiM Ultra to Schiit USB DAC with the Nitsch analog circuits is a killer.
Isn't this Schiit interface used between the source and the external DAC? If so it's basically a more expensive version of the SMSL PO100pro and as such has the same function.BTW- The Nitchsch DAC with the Schiit USB Multibit / Unison interface doesn't need those USB reclockers......
I'm not into expensive ready made units as they are most often compromised as to not take away the profit of the next higher unit.
It doesn't take much DIY effort to get at least the same sonic results for about a third of the price.
This is my setup made of modified Chinese boards and it actually is the most analog sounding digital playback I have heard to date.
Cost about $320 including the very good silent switcher to power the Accuphase clone board and the DAC.
The Cary SLP 90 tube pre clone is optional but extends the soundstage in all directions without loosing any details.
This was of course a test setup.
It will all finally go into a nice case but with the Chinese Fifo DDC.
Klaus
"...the most analog sounding digital playback I have heard to date."
The Schiit includes the USB interface with the DAC. Have you heard their DACs with the Multibit Unison USB?
Think of it as a DAC that has its own internal reclocking interface. Mike Moffat is the guy who started the outboard DAC business with Theta back in the mid 80s. And I can tell ya from experience that his stuff sounds really good and is not Hi End Expensive. The Nitsch is indeed a rare version that is hand made and includes the multibit unison with some really well made analog level.... it's hand built and it's not one of them limited units as there is no unit above it.
The only reason I'm considering getting one of the Schiit units is because I want the balanced output. ( I don't need it, just want it ). And, btw, I don't know what "expensive" is to you, but anything under 1000 bucks is not expensive... sometimes spending just a little bit of money does give you the value.
However, I do agree with you about modifying stuff.... myself when it comes to such things I prefer to just op amp roll and maybe get a better power supply.
My issue with buying so many Chinese made "clones" is that they are ripping off Intellectual Property.
Building clone Pass amps is fine as Nelson is OK with that so long as people don't go making a business over it.
As an R&D guy, I do not condone, nor support, companies that steal IP, sorry.
BTW- those are Burson V7 op amps, huh? Don't tell me you got some Chinese knock offs...
No these are real Bursons. I got the V7V's and the V7 Standard's from Burson to post my honest opinion
Sparkos ss2590 are better though.
If patents are expired I have no problem buying Chinese clones.
The discreet part of the Chinese Accuphase C3850 clone is the best output stage I tried on the Chinese r2r DAC a hint more dynamic and spacious sounding than the Sparkos ss2590.
Btw the Fifo DDC and the DAC are genuine inventions by the Chinese. The DDC even has it's own thread here at DiyAudio.
If it only takes the mentioned amount to significantly increase the sound quality of the Wiim Ultra it's a no brainer. The internal dac isn't even close.
Klaus
Klaus
Simple... don't use the internal DAC in the WiiM Ultra. Just use it as a bridge to go from ethernet/WiFi to USB to support bitperfect from Android and Chromebook....
How many times must I repeat myself about this?
It also allows nice wireless control. and I don't need a DDC. You might want to catch up with the discussion about the Schiit Multibit/Unison USB interface. You don't need a DDC.
I have the Bursons... all of them since V4. I prefer the V7 Vivid although the V7 Classics are very nice too. Haven not tried the Sparkos.
I don't buy Chinese clones, sorry, no way. I make my living doing R&D and creating Intellectual Property... I consider them thieves.
I've been noticing quite bad lip sync issues watching TV with my Ultra. Using hdmi arc and the internal dac and analogue outputs. One time it suddenly came good when I reopened the app in my android tablet. ( I have the app on my phone and the tablet). But the last time I could only resolve by restarting the Ultra.( Unplugging the mains).
If you drive a car you move by multiple stolen technologies. I got a friend who worked in the Car industry as an Engineer. They regularly disassembled cars from competitors just to see what they could copy. Maybe with a little twist just to not infringe on patents.Simple... don't use the internal DAC in the WiiM Ultra. Just use it as a bridge to go from ethernet/WiFi to USB to support bitperfect from Android and Chromebook....
Strictly speaking any cover band just copies the invention of another artist.
It's a concept that follows us through all areas of life.
Enough said, I take sonics over dogma any day.
Klaus
Yes lip sync problems com and go. Pause and play again helps most of the time.I've been noticing quite bad lip sync issues watching TV with my Ultra. Using hdmi arc and the internal dac and analogue outputs. One time it suddenly came good when I reopened the app in my android tablet. ( I have the app on my phone and the tablet). But the last time I could only resolve by restarting the Ultra.( Unplugging the mains).
HEADS UP.
Amazon Flash Sale... for the next five hours... 279. I think I'll buy another for upstairs or my wife's office.
Klaus
Fine, don't expect me to agree with you.
I work in R&D.
It's not dogma, it's PRAGMA.... It's my paycheck they steal when they take the IP.
Look at this.... IMHO, customs should not allow these things through... I don't care about your "sonics over dogma"... you are supporting theft.
Copy Accuphase A75 Amplifier 120W*2 HiFi Home High-end Audio Sound Amplifier Stereo 1:1 replica original Circuit.Hifi Amplifier
https://www.aliexpress.us/item/3256808707789335.html?spm=a2g0o.productlist.main.5.2c17hNikhNikyF&algo_pvid=6f61e801-1b3b-4db8-9b07-9aa414f25e31&algo_exp_id=6f61e801-1b3b-4db8-9b07-9aa414f25e31-4&pdp_ext_f={"order":"-1","eval":"1"}&pdp_npi=4@dis!USD!908.62!826.84!!!6551.00!5961.41!@2103247417469135203694534e46bc!12000047110194677!sea!US!6323684121!X&curPageLogUid=6U3lWknEkMMV&utparam-url=scene:search|query_from:
- Digital Source
- WiiM Ultra: who has it and who has already opened it?
