How to build the best possible audiophile desktop?
With so much optimization into the system -- do you cover the bare, hard desktop with fleece or something to absorb HF, as you listened well off-axis to the "linear array" of reflection from below? I'm sure your arrangement works; just trying to understand the subtlety of "driver on the reflective mirror-surface" pros and cons. Thanks.
WChang ~ great point and this is the downside of the "surface mounted" salad bowls... I have thought of trying to "fly" them adjacent to the panel but the bracket fabrication task seems a bit daunting. I have measured the bowls pointed out & away from the reflective surface and they are flatter there. Too, they have better bass performance backed up closer to a wall behind them (but the sub covers a lot of that issue). Still, perhaps some desktop pad ideas might be right to try... thx.
Per suggestion, I added a sheet of cork to the NestDesk surface and it did smooth the SPL sweeps some, and it sounds better. It's still a plane in front of the speakers so while they are great, I know there are reflections.
I also built a wild suspension mechanism from 1/2" x 1/8' aluminum bar and attached it to the back of the monitor on the Vesa adapter. I simply hung the speakers on the forward jutting suspension ends via the rear-firing bass ports. It was too wobbly and insecure and I took it down; the speakers are pretty heavy. I'm sticking with the desk pad though.
Orthogonal axis - should be minimal. If the axis were parallel it’s a different matter. I see it is one of the configs where TG says there is crosstalk. It’s the same channel - I’ll measure and see if there is a big effect.
The measured response of the speaker with the external and internal (compact cross-axis inductors) are very close. There is a small difference at about 550Hz but I am nit sure that is due to the filter as it could be partly external since measurement not on same day. Distortion is also about the same. I am just going to leave it as is as this is within acceptable limits.
Comparison of Freq Response:
Harmonic Distortion with Compact Internal Filter:
Harmonic Distortion with External Filter:
Please allow to make my submission of the best desktop I was able to build. The speaker build details are in this thread.
It's a Tang Band W6 coaxial build with passive crossover, and additional EQ to make it smoother. About 20 L sealed, no port as it's near the wall and me, almost headphone mode. Pics in the link above. The curve I'm currently listening:
Measured on computer desktop from my listening position 2 feet from the speakers. Distortion:
I'd be curious to know how it stacks vs other solutions proposed in this thread. As I have no way to know let me provide some subjective feedback.
I have no listening fatigue with my chain. When I WFH I'm usually binge listening for 10 hours and it feels good - perhaps that was the main goal 🙂
At this point my speakers are definitely not the bottleneck of my system, the large impact I have now is the power outlet noise from various devices like washer/dryer and heater, the sound changes during the day based on who knows what.
The speakers and chain resolution is high enough that besides the power the other large impact is the source. I was attacked for this several times so to avoid another flamewar let me say I have a strong subjective perception not based on any facts that the best HiRes recordings sound noticeably better for me than the best CD recordings. I also have an illusion that rolling opamps makes a lot of difference. At least HiRes with proper opamps makes me happy.
Another subjective criteria of where those speakers stand is to compare with live music. First of all, where they don't compete. I've attended >20 operas at NYC Met Opera and a dozen of symphonic concerts at Carnegie Hall and similar venues in metropolitan NY area. That's a totally different level, no compare. I also attended >150 operas and concerts in Europe. There your mileage can vary - some lesser venues are using an amplified sound and the sound could be worse than what I have at home.
Now where my speakers are better. I've attended >60 musicals on and off Broadway, in NYC and metro NJ. Of course there are many shows I never saw, but I saw pretty much most music venues in Manhattan, including those in Times Sq vicinity. As soon as the mics and large black speakers are involved, that's it, my stereo sounds better than this "live" music. Soundwise, Broadway annoys me. The sound is flatter, more distorted and less resolving. I can recall only two exceptions - "The Cats" where I sat at the 1st row and "Farinelli and the King" where Iestyn Davies was singing without microphone, good for him, and I also was pretty close.
The Hadestown: Live From London is so well recorded that I have a full illusion that am on stage and the singers are literally 15 feet from me. The sound is far better that almost anything I heard on Broadway.
Small Jazz venues are usually unamplified in Manhattan, and in New Orleans, so they beat my speakers. But as soon as I move to something like large BB King, that's it, even Jazz may sound worse than what Tang Band delivers. Rock and pop concerts - forget it, they are basically unlistenable by quality and too loud anyway, live rock is dead to me.
The details, soundstage and instrument separation: Mahler: Symphony No. 2 instruments are spread wide and deep, they sound as many separate instruments as they should. Il Trovatore choir consists of several singers singing clearly separately with their voices. With the full choir some of them are still separate, but females mostly sound together, I can split them only during the final 10 seconds.
Texture and air: Step Into Paradise the pianos are rich and deep, the voice is textured and detailed. The room acoustics is very present, I have the full illusion of being on stage. A lot of difference in how the keys are pressed.
The bass: Sarabande goes very deep, the electric cello still sounds like a cello, I definitely hear the instrument texture, the bow movements and friction are clear. Longing the strange drum there gives multiple clean reverberations, it sounds like multiple frequencies overlapping, very unusual sound. Both bass and treble are very airy.
Saxophones, trumpets and other wind instruments are very clean, along with grand piano those are challenging instruments and those speakers do them well. Voices are amazing, with best recordings they sound like a real human, all the peculiarities of the human cheeks, tongue, throat and lung voice are very clear.
I am mostly giving this review as a speaker review because that was the largest leap forward for my chain ever, compared to my previous Dynaudio speakers it's night and day. I strongly recommend this build however it's a complex build, you will be laughing but it took me 5 months of work (my first DIY speaker ever). Read the whole thread for all the caveats. Special thanks to @perceval for guiding me through the process.
of course there is.
It is a 6.5" woofer, in a small enclosure, and designed that way.
If you have a single driver that plays from 20Hz to 20kHz (aaawww, the quest for the audio Graal... cute),
then you like distortion a lot more than me.
Why not use a multiway wide band configuration ?
The wide band transducer is assisted under 80Hz by a small closed box woofer and under 50Hz by dipole subwoofer ?
It is extremely compact with a 8" subwoofer.
PS : it is an unfinished prototype (lack of decoupling... it rattle everything on the desktop)
Completely different approach. We are doing with a single coaxial driver, and excellent imaging, some of the best I've ever heard.
50-ish Hz to cross to a subwoofer is very easy to do.
Are your little drivers separated from the 8" woofer chamber? If so, then hey can't have much space to breathe inside there.
If not, how do the vibrations of the bigger woofer not affect the smaller drivers? That would cause havoc on the smaller drivers and induce a lot of distortion.
Rattling the desktop... again... unwanted distortions.
You do not seem to be bothered by them. I do. I really hate distortion. It doesn't play nicely with my ears.
I'm happy to see you are trying things as a DIYer. That's what this forum is all about. But to me, it is a direction I will not take. I prefer good imaging, a very good FR and phase, and distortion-free setup.
I have no hifi pretentions, haven't measured the distotion of my loudspeakers, so i will not say how the vibrations affect the rendering if it is the case.
Moreover i don't know if it is usefull to mecanically decouple all the enclosures and if the direct field of the subwoofer really affect the FR driver much very well below its resonances modes.
grazie a tutti per le risposte. 👍
@audiosteve
I didn't see how you made the box, if you added crossovers, but maybe with a power supply with a few more Amperes it could still improve the sound. maybe with 15A
It's just a simple stuffed box. The driver in that box doesn't need a crossover or EQ. A 15 amp power supply would be an unnecessary expense and a waste of power. This is a very small class A amplifier which has low power but more then enough for desktop use. The power supply that I'm using already supplies more current than is necessary.
now that's some heavy designing. And 3D printing?
I do think you should measure this as much as possible and try to make the best you can achieve. Looks like a fun project. Don't settle for good enough. Push it as far as you can.
Félicitations!
View attachment 1457859View attachment 1457861
You remind me of someone who walks into a sports-car-shop and asks where the RVs are 😀
The speaker-ideas in this part of the forum are fullrange-based. Your approach might be more suited for the multi-way-part 🙂
