Using a different woofer in the LS 3/5A box
an update on the Tweeter: kept the inductance from 0.5 and switch to cap from 4.7 100v to 3.3 250v polypropylene. the tweeter is less intrusive in the low end and has balanced in the high end.
all these precautions will be swept away when I will do a simulation of the frequency response. we will see some beautiful things 🙂
Reactions: AllenB
an update:
  • b-amp cross
  • mid-woofer / Zobel
  • tweeter change to 4 Ohm slightly bigger and Zobel.
:violin:
Buy a proper woofers and kill all the competition in the village 🙂
here we are with the last and definitive version in photos of the Crossover in its standard dimensions (120 * 130mm) to be mounted on the back of the Tweeter as LS 3/5a.
I'm still in listening / testing mode because alternating Carver M 1.5t and Jeff Rowland model 1 I could make a last change to the Tweeter, regarding the attenuation with R1 1.8 & R2 4.7, but we'll see.
For now this is all and the sound is good.
:cheers:
:violin:
Reactions: AllenB
