So i impulse bought a sub. What would you do with it?
These have to be so big to get decent low frequency output that most people would prefer to cheat with a Helmholtz resonator I think?
But the strategic (convenient with two drivers) driver offset sure helps get rid of the junk in the XO region .
What program do you use to make your box drawings? They always look so nice!
💚So much better than the old paraflex designs. That thing is just as smooth as an 1/3 offset driver TL, but with way more ‘gain’ if you compare.
Pull the just bottom
Section(s6-s9) off and look at how the air mass of the short resonator affects the bandwidth and output . It’s really cool
(Strange way to simulate the actual shapes of s7-s9 in the box and exit @ L45 , but what else can you do)?
I wish I could get more drivers to work so smoothly in these. The results are really good when it actually works
(I still Think mine is ‘overdamped’ and too conservative for us ‘bassheads’ ?)
21.75" x 12" is probably the smallest CSA you would want to use.
I actually looked at 11" > 6" > 11" segments, kinda like the Paraflex stagger....313mm = 12.32" > 254mm = 10" > 279mm = 10.98".
I'm using Ap1 & Lp as S1 to S3...we need a 5th TH segment!
Basically, it's a stepped flared port TH.
I get the same results, different design without the polyfil and phase issue, unless i tap into the high tuned resonatur and cause it by altering the length) sounds pretty good unless a bass guitar is ‘muddy’ or male vocals stir up some ringing/howling. Weird amplified funk coming out a big mouth/vent is annoying as heck …
You gotta really screw up the resonators to get that green graph of the original type A. It 💩s the bed @ 3 x Fb as a result and rings like crazy.
It’s ALL a lot better(anything high order qw) if I use the Peq like @glaxar suggested earlier in this thread (instead of relying on a generic xo slope )
Some music just plain sucks in those resonating pipes I suppose, we Cant win them all 🤷🏼
Nothing sounds as good as a big fat tapered qw pipe with polyfil in it though.
