PETTaLS Flat Panel Speaker Simulation Software
From the impedance curve, I wonder why PETaLLS shows peaks around 2k like if some modes are visible in the simulated impedance curve, not in the measured one but peaks are visible on both SPL curves...
Christian,
I'm not certain that I understand what you are saying/asking, but the measured impedance did show peaks around 2kHz. The first was really small, and the second a bit larger. The two peaks did appear at a bit lower frequency, and smaller peaks, in the measurement, than in Dave's revised hi res sim.
Eric
Reactions: homeswinghome
The link in Post #1 is still not the correct one. I used the link in Christian's Post #6 to download the latest version.
Eric, I think it would be good if Dave also has editing rights for Post #1 to update future links. It is as simple as asking a moderator to arrange that.
twocents,
Such little faith you have in me! Haha.
I think the link is correct now, at least it's the one Dave asked for. I was traveling for work all last week and couldn't do any editing except via my phone, which I'm not so good at. Meanwhile I did request for Dave to be given editing rights. No response just yet.
Eric
Here are the results of my recent work to model a range of exciters... the math and everything behind all of this is something that I'm going to save for a publication, so that'll hopefully be out later this year.
first, graphs of the measured and simulated impedance when the exciters are simply stuck to a desk.
Also - graphs of measured and simulated impedance when attached to my aluminum panel. The exciters that have missing graphs are the ones that didn't survive being removed from the desk 🙁
It's interesting to note that the majority of exciters are modeled pretty well here. The DAEX32Q-8 is not well modeled, unfortunately, because it has a pretty complicated construction. That one probably needs a much more complicated model. Also, the "EX" exciters rather than the "DAEX" exciters are the ones with the plastic disc coupling surface rather than the voice coil ring, and these seem to have a much faster drop-off in impedance peak amplitudes with frequency than the ring ones. This corresponds to a drop in panel velocity and volume, so these exciters appear to work only at pretty low frequencies. I'll have to do more work on this and see if these results carry over to over plates/materials as well; not totally sure yet what to make of that.
PS I had a bunch of DAEX19CT-4's, so the simulated and measured impedances use different individual units. This can give us a rough idea of the manufacturing tolerance in these exciters.
Reactions: Veleric
Hello Dave,
Impressive collection and basis of an excellent database.
An exciter has 2 moving masses, the voice coil and the magnet. Between them the spider and force based on the current and the magnet. There are 2 resonant system depending the voice coil or the magnet is fixed. In the Xcite specification both frequencies and parameters are specified.
The plots before show the fixed voice coil situation.
Generally I am more considering the fixed magnet situation, probably as an heritage of the impedance simulation of a cone loudspeaker but also because my final use of an exciter is with a fixed magnet.
This might explain I haven't understand the parameters you gave in post 205...
Have you also considered the fixed magnet situation?
Opening one Xcite specification, I see they give a unique value of the compliance which make sense; it is the same spring if the voice coil or the magnet moves but there are 2 values of Rms.
Some weeks ago, doing impedance measurements by adding weight, I came to the observation that Rms depends on the mass or maybe something else. To explain more clearly, if I have the value Mms, Cms, Rms for one Mms situation (ie free voice coil), the simulated impedance with the according RLC circuit is pretty correct. If I increase the Mms (ie + 1 to 5g), the change of the according electrical component is not enough to get a correct impedance curve. The Rms changed.
Do you know the explanation to that?
Christian
Dave,
Any idea what's up with the 25FHE-4? The one's I have seem to be similar to your measurement. Both of mine have a peak at around 27Hz/20ohms when the voice coil is attached to a rigid mass. Any idea why the sims show the peak almost 10 Hz higher (as best as I can guess from your plot).
Oh, and any luck getting any Xcite units?
Eric
Dave,
Eric
I have 28.5Hz/23Ohms
To give an illustration to my question of the Rms, I did this graph some weeks ago. It is a small cone speaker. I could do the same for an exciter. The height of the peak decreases when the adding mass increases and in consequence when the resonance frequency decreases.
With a constant Rms, the peaks should have all the same height.
Does it mean Rms is a function of the frequency? Leading to a nice constant Q?
