Iron Pre Essentials Kits For The DIYA Store - Register Your Interest
Success! Zen Mod Iron Pre sounds amazing and is dead quiet. Thank you Zen Mod and Nelson Pass for sharing the design and expertise.
Thank you itsallinmyhead and 6L6 for curating and organizing the information in addition to the excellent build guide.
Thank you FrankWilker of AudioPerfect for your excellent Muses implementation and guidance in selecting the right solution.
Dialed in all the test voltages easily, and fired up first time. Sounds excellent. I was not aware of Frank’s solution until I was about 90% done with the Iron Pre. It is definitely possible to solder in his 90deg pcb solution after installing transformers but I wouldn’t recommend it. You can see where I kissed a relay with a hot iron, but only cosmetic. For now, the IR receiver is peeking through a 6mm hole in bottom plate. I will see if it will reliably accept bounced signal from the shelf under it. I brought the programming leds out of back of rotary encoder so they may be observed through the vents of case when programming the remote control. This is in front of my Aleph JZM driving Belle Kipschs and I am very happy with the sound. Thank you to everyone here on DIYAudio for their knowledge and willingness to engage in civil discourse.
If you have any short on the output for right channel. Check that you have high resistance between the two RCA pins on the right channel. Those high strand count wires can sneak in a single "frey" from (signal out +) to (signal out ground). Easy starting point.
@bilsch - First three things I'd check are below. (Don't know if you're balanced or SE)... Always post details of your build and pics, otherwise people are just going to ask for them.
1) Input - input signal makes it to the board. If not... fix wiring.
2) If yes to 1 - Check to see if signal gets to output pads using correct input selector (check a couple of the inputs). If yes, fix wiring.
3) If no - check to see if jumper header is installed? If signal gets in ... but not out... that's an easy win.
Reactions: birdbox
Hi there, making progress on this amp. Dim bulb startup was uneventful and DC settings made. No smoke. I did forget the jumper headers and when I went to put them on they fit loose. I can’t figure out what’s up with that so I ordered more. Here are some progress pics of my very diy effort.
I gave the IP SMD I made a year ago to my kid, and have been slowly building another for myself. I finished it a little while ago, but it has low output syndrome -- it appears to have some kinda negative gain; it's too quiet and/or doesn't get loud.
Today I borrowed my kid's preamp for comparison. They both have Frank Wilker's MUSES volume solution, and sure enough, the new one was quieter (for lack of better terminology). I pulled the MUSES stuff out of the new preamp and put it in the old one and noticed no difference (that is, the older preamp still played significantly "louder" at a given volume regardless of the MUSES card installed). Hmmm. Voltages measure correctly on the new boards, and both channels exhibit the same issue.
And I'm a little stuck. Any advice happily accepted. I have a feeling I've done something dumb and just can't see it.
Thanks,
Tim
Reactions: ghitus
