After installing the Supaspin I have been listening to my records in the past days and I would like to share with you how happy I am with the now completely silent motor on the Music Hall MMF 2.2. It is “just” a Pro-ject 2-phase motor that was humming a lot but apparently with decent motor control it can be made completely silent.
Likely the original drive electronics fed it a square wave or something other than a sinewave which would definitely cause the motor to hum.
So if I wanted to try this with a VCR video head motor what all parts and pieces would be required.
I took a look at the waveforms for my low-voltage 2-phase motor driven by the original AC-adapter here, not too square but not too pretty either.
The fact that the waveforms were kind of flat on top might have been enough to cause the vibration.
Correct. Assuming the current is equal in shape as the shown voltage plot, all other frequencies besides the 50Hz ground harmonic in the frequency spectrum do not contribute to the desired mechanical rotation. They do generate forces inside the motor that will introduce the humming noise. What also helped in lowering the remaining humm is that I lowered the amplitude of the driving signal from ~16V to 9V RMS for 33,3RPM.
By the way: the motor was originally ‘controlled’ by a simple circuit using an elco as 90 degrees phase shifter. I have not measured the waveforms but they probably were very non-sinusoidal.
Thank you Richard!
Finally I managed to finish rebuild of almost complete TT. Don't thing it is best in the world, but at least in my opinion it is one of the prettiest, at least for me who like understated retro design loaded with contemporary features:
It is still on my work bench. Need to clean and adjust tonearm, and play with preamp again. Also still looking for shaft encoder to properly measure W&F.
Also I envisioned cover, made from commonly available poly-carbonate sheet that I bent with help of steel pipes and heat gun. Cover is still in design phase, but will come in soon...
I've got a Sansui SR-2050c record player that runs slightly slow with the solution I chose being to convert an audio amplifier to a variable frequency AC supply.
Is there an easy to find motor which will work with this, fit the Sansui and have a pulley on it for a flat belt?
I'll start my own topic once I get a definite plan together.
2 (0, 90°) or 3 (0, 120°, 240°) phases of sinewave generation
Is that for using with permanent split capacitor motors or specific two phase motors?
I'm looking to add this to my Sansui SR-2050C record player and wanted to be sure if that would work as I can likely easily get one of those that has a pulley for a flat belt.
Also are there any examples of AC motors in vintage equipment that might work well for this?
What class of amplifier is preferred to drive a motor with?
The Sansui has two buttons which move a lever to shift the belt between one or the other motor pulleys. Since the button for speed selection is momentary push is there a way to make it to where the speed can be selected by the Sansui's two buttons?
It should be applicable to any motor type which requires the phases aligned as shown. With a trim range of +-30 degrees relative to nominal, this would allow 60-120 degrees in 2-phase mode, and 105-165 in 3-phase mode, so 60-165 degrees overall.Is that for using with permanent split capacitor motors or specific two phase motors?
The easiest way to find out is to measure the relative phases of your setup when running, or as has been shown here, measure both phases of the EMF genereated when driving the motor.
Whatever works! We're not seeking high-end performance for the motor drive, there are various examples of class-D, class-B and chipamps being used.What class of amplifier is preferred to drive a motor with?
It curently only supports a momentary push-switch for speed change (and start-stop + menu selection).The Sansui has two buttons which move a lever to shift the belt between one or the other motor pulleys. Since the button for speed selection is momentary push is there a way to make it to where the speed can be selected by the Sansui's two buttons?
https://www.electrical4u.com/split-capacitor-motor/
Therefore, it creates a 90˚ electrical angle between main winding and auxiliary winding.
So that type of motor would work.
My thinking was to try one of those AC motors from an early 8 track player given it already has a pulley for a flat belt provided that type of motor won't induce hum into the cartridge. The problem there is generating around 120Vrms to make the motor work.
Cladd D I cannot do as it will interfere with AM reception unless there's a class D amp that produces no RFI.
Since it's a momentary pushbutton I'd need some way to for instance connect a reed switch and magnet so that the reed switch operates when the magnet passes by it as the 33 button is pushed and operates again as the magnet passes back by it as the 45 button is pushed.
For the circuitry I'd likely put it in its own separate box so that I don't have to cut the cabinet of the Sansui, however if I do that then why should I bother with the 33 and 45 buttons working. Plus by not modding that it keeps it more original so that it can be put back stock if so desired at a later date.
Just thought about it and those early AC 8 track player motors rotate the wrong way to be useful here, but do rotate the right way for a rim drive phono. That said it would be easier to stick with a lower voltage motor as I wouldn't need amplifiers capable of producing a high output voltage.
Just need to hang the motor upside down. It could be an awesome motor pod design.early AC 8 track player motors rotate the wrong way
Would be hard to do with the Sansui since the motor location is under the platter.
I have (amongst many others) an original AR turntable; sadly the motor is kaput. there's so much play in the motor bearings you can almost see the pulley precessing as it turns. As I have both Pyramid's SG4 and Rich's Supaspin controllers I went looking for a small, cheap, and easily available 3 phase motor. Scrolling through the 'fleabay' listings I came across these:-
https://www.ebay.co.uk/itm/23553663...OiVQyazq4gN8KX3G3o75cZFzM=|tkp:Bk9SR9aHgJ_dZQ
They run almost completely silently, and have a long sleeve bearing. Best of all they're around £12 each.
I've fitted one to the old AR and even with the very old belt I can achieve 0.07% W&F.
Interesting. On the Ebay page one picture shows that the motor has embedded electronics. How did you connect the motor coils to the Supaspin?
If you look at the picture showing the underside of the motor (pic 4), you will see 4 solder connections between the windings and the pcb.
I unsoldered these, bent the tags back and removed the pcb and then attached wires. The three single strands are the 3 phases, the 4th, where the other ends are connected together to make a star, this connection can be brought out as a common point, or as I did in one of my motors, separated to create 3 completely individual windings.
You do obviously need three small power amplifiers between the Superspin and the motor.
Has anyone tried one of the super cheap Chinese BLDC motors like this? https://www.aliexpress.com/item/1005008174900247.html
I'm looking for a BLDC motor that is readily available new, small in size and lightweight, with a 3 mm output shaft and sleeve bearing. I don't have a supaspin yet or I'd try it myself. I realise an external rotor motor is not the best for a retrofit but I'd be interestsed to know how smoothly / quietly they can be made to run. I like the idea of the motor Ralph links above but it's a bit too big for the turntable project I am working on.
- Analogue Source
- 2 phase synthesised sinewave generator for synchronous motor drive
