12V 555 based High Voltage power supply
Hello Gebrey,
I've uploaded the HV power supply project I'm working on. I should have the first prototype ready in about two weeks.
https://github.com/stefaweb/audio-psu/tree/main/HV-MODULE-UC3845-1.0
In addition to the HV module, I've also created a board to mount the module, add a 30 KHz output filter and manage the negative voltage for the BIAS.
https://github.com/stefaweb/audio-psu/tree/main/TUBE-HV-PSU-45W-1.0
So far, I've only tested it with HV Chinese modules at 350V/60mA and -60V.
Stef.
Reactions: Gebrey
Wow! What a job!
Since Im a beginner in this field I have some questions.
I barely understood the suggested UC3845 scheme.
This one is so improved!
Let check if I got every implementations.
Red area: voltage regulator. But... why we need it? UC38xx allows for 36V max rating. We could use 24V directly. My project would involve max 18V.
Green area: why 2 primary in parallel?
Yellow area: what is -HVo? Is it a predisposition to have 0 as virtual ground?
Why are these caps doubled with 2x 1M resistors? Why not just 1 cap and 1 resistor?
Cyan area: feedback circuit to comp pin? And is the switch MMBT3904 in purple area used to power off UC switching via comp pin instead of turning off for absence of Vcc?
Green: look at the Wurth transformer specs. The transformer is upside down.
Yellow: the module can output more than 500V. It's less expensive to use low voltage caps. Caps over 500V are also hard to find. The 1M resistors are used to balance the caps.
Cyan: The LM358 is only used if you want to create a negative voltage with the module. The circuit with the MMBT3904 allows you to create an on/off with a low level signal (external time delay by relay on power-up).
The "-BIAS" is used to output -150V/-200V to control a tube's BIAS (no load) with the second PCB which contains a divider bridge to go between -30V and -80V. It is experimental. I have not yet tested this configuration with my module. It works with the Chinese blue module that I tested as a prototype or I even put 2 diodes on the same transformer winding. The problem with the blue module that I tested is that the transformer is too small. We can only output 15W. The yellow module does not work and is even dangerous (among other things the overvoltage circuit is defective and it outputs 650V at times at startup).
The module's frequency is 47KHz, far outside the audio range. I added a 30KHz filter at the output on the second PCB to filter out anything coming from the AC-DC power module (as the IRM-45-24).
Finally, the schematic is one thing, but the most important thing is how the PCB is made (Look at the ground planes on the PCB around R5). Chinese modules are particularly poorly made, even though their schematics themselves are functional.
Stef.
I still don't get it. That symbology means one sec is wounded around the other sec? What does that imply? Stronger inductor I guess. We lose half of the potential of the trafo if we skip one of these wounds.
Yellow: the module can output more than 500V. It's less expensive to use low voltage caps. Caps over 500V are also hard to find. The 1M resistors are used to balance the ccaps.
Got it. Also, 1M resistor let caps discharge when power off, right?
Mmmh.
Without LM358, is the trimmer RV1 that change sensed voltage (feedback) to adjust Vo.
With the LM358, we invert the voltage sensed to let UC3845 senses and produce negative voltage? I'm not sure.
Also for the presence of these diodes at Vo.
If I want a negative voltage, why simply swap + and 0?
Example.
  • + = +500V 0 = GND
  • + = GND 0 = -500V
Diodes are fine.
So, D1 create an half wave rectifier.
D2 does the same but for the negative part of the wave (negative voltage) and I question if C12 and C13 polarity is right.
A SUGGESTION:
The 15V aux (Wurth pin 5 & 6) could be used to feed Tube heaters like with a LM317 @12.6V if we don't want to take it from UC3845 source.
Hi Gebrey,
Sorry, I'm in vacation. I don't have time to answer all your question.
The schematic you posted was still under development. Since then, it's evolved quite a bit. You can check the GitHub repository from time to time. It's best to avoid posting provisional schematics online here. This can be confusing.
I'll resume testing the prototype when I get back in early May.
Stef.
