Single Ended Double Tap Ultralinear Transformer + Schade config. tests
Not really Walter
The picture on article of Schade is different and on it I am playing
And the consideration about % would be the same for Bartola and also dependance on tube type
Unfortunately I am servicing my Sofia that has an issue so I can’t play with it
What I see they aren’t test in deep around Schade config but the first impression aren’t good
I will go ahead
Walter
That's why I suggested you to study and investigate more based on the evolution of the concept, suggesting different circuits and tests of other people, not just the original paper. It's not only a matter of the tube itself, but also the right driver to chose for this kind of feedback.
This forum (and all the related links outside the forum) is full of information of people who measured the curves of a moltitude of tubes applying different local feedbacks.
Each pair of valve and configuration give a specific result, and a specific limit for the amount of Schade feedback after which the increase is detrimental for the overall amp. To understand these points you need to read tests and considerations by other experienced people and understand strong and weak points about different configurations.
If your first impression is not good, it means you are not doing things right.
There are the first test I post here and they say something
And look around I never seen the same pattern of test with real circuit and not simulation
The way I follow is right
And other test wil be done
I have four different OT to play with different config so at the end some consideration will come
Walter
The link I posted in the previous page is a curve tracer showing results on a real tube. It's plenty of similar information on this forum.
Others have shown results of complete circuits decades ago on this forum and linked other tests outside the forum.
Some data has been lost over the years (a russian forum with tests varying Vg2 and Vg3 is no more available), but most of it is still available.
You just need to find them without reinventing the weel.
These below are Schade feedback curves obtained by a curve tracer 12 years ago:
Reference: https://www.bartola.co.uk/valves/2013/03/16/307a-dht-in-triode-and-schade-feedback/
Hi
Can someone draw the schematic and explain with formula Shade concept?
How to calculate amount of Feedback? what is the elements configuration etc.
Please?
Is feedback amount, ratio of R2 / R1 in this schematic?
The artcle
https://www.dos4ever.com/uTracer3/Schade.pdf
I am playing with different config of FB
Walter
THANKS
Now it is a significantly more clear.
feedback amount for n less than 1 where 1 is 100%
n = R1 / ( R1 + R2)
I will redraw the schematic to more clear variations.
there is some mismatch on the schematic 50uF/35V should be marked as C2
last line in the picture...
btw
on Bartola Schematic R1=10K Rpot should be set to 90K for n=0.1 10%
"G" point is not for the input signal as from the way of drawing could be conluded, BUT for negative grid bias.
This is for measurement only - that was confusing...
For operational circuit, we need couling C in between R1 and R2 at the very G1 pin3.
With R1=10K, it is actually Rg, that coupling C should be minimum 10uF.
Note that in original Shade sch transformer used - not coupling C, so the 10K value is more appropriate.
I also built a balanced PP pentode amplifier without general feedback, but connected to Shade which behaves like a PP triode, but with pentode power. I basically connected only 2 resistors...
