TPA3118, TP2020, TA2024. Which 24VDC Class D amp of today has outclassed these chip amps of yesteryear?
If a power supply (single or dual rail) is separated from the amplifier then it will not work in either case. "Convenient": I think it is a decision based on emotion not technical grounds.
Not really. In my case, I like having everything small and portable. I tend to build (loosely build meaning wire up) TPA3118 boards in Altoids Mint containers. I can put this in my pocket and throw the 24V laptop brick in a backpack or whatever else I happen to be carrying and I happen to have a bunch of them all over the place. It's just a convenient power supply and the TPA board is so small that it's super portable. Weighs in the ounces instead of pounds.
Can't do this so easily with a chassis or 2U rack mount which would be required for a dual rail supply.
Of course but “portable” was not mentioned as necessity.
Like you I like small devices over large devices but never take them with me. My AO200 Mk II measures 210*194*41mm which is pretty small. My DIY amplifier is about the same. Both with internal PSU.
Reactions: 777funk
And unfortunately I've had the fake one burn up a speaker at one point. It put full Vcc on the speaker terminals and made smoke! Thank you China! I guess that's what I get for trusting China in the first place. I definitely learned to count pins after this event a couple years back now.
I have been building and using class-D modules based on genuine TI-chips for about 12 yrs.
Not a single burning failure occured during all these yrs.
These chips look pretty reliable to me, never used additional speaker protection.
Never had that either with any TPA3116/3118 contrary to TA2020, TA2022, TA2024 and very unfortunately MA12070 (the already discontinued king of sound). The ones you love hurt the most 🙂
MA12070 likes 24V single rail but make sure to read the addendums to the datasheet and/or choose a fully equipped ready made version! Maybe TPA3156D2 is exactly what you like. Haven't tried it myself yet. If you build it with internal 24V PSU and DC jack with 2 x Schottky diode "best battery system" you can have the benefit of both. One less brick to carry.
https://www.ebay.com/itm/325126574459
Reactions: 777funk
You still did not get the point.
Only working output MOSFETs can be disabled by internal protection circuitry.
Burned ones are melted and short the output to supply voltage no matter what internal protection is doing..
You cannot block a melted MOSFET by removing its gate voltage
I think you may have mis-read my last post or perhaps it wasn't worded very clearly. What I had asked is if there's something inside the package (TPA3118) case that disconnects the MOSFET output transistors from the load. I seem to have read that this chip has DC on speaker output protection. I think it's stated in the datasheet.
Fortunately , I didn't faced this issue but these AliExpress fakes can't handle difficult 4 Ohms speakers with impedance dips. Audio cuts out during deep bass and a sensitive tweeter emits continuous buzzing sound, audible during quiet passages I'm using these for the last 5y regularly as a PC speakers (6 Ohms Sony ) with a Laptop brick @19VDC. I also have a Allo Volt amp with the genuine 32 pin IC, it handles 4 Ohms gracefully those same speakers.
I very well understood your posting. DC offset protection inside the chip works in case of input dc imbalance and similar and will disconnect power MOS gate drive. There is no way to implement a distinct "power disrupter" inside a semi. So the short answer defintiely is "no". At the very end you always have to rely on the ruggedness of internal power transistors. There is a plethora of chips on the market or obsolete ones well known for "mysterious" failures. These TI chips are not in my black list until now.
This one is good, but this one (on the left) is even better sounding. I could never figure out why. I did some swapping of inductors and caps. I didn't spend more than an hour or two on it, but there's a difference.
Reactions: availlyrics
I haven't read every post in this thread and there are so many here that I can't keep track of who has said what about what. Sorry.
So I gather you have had a TPA3118 (GENUINE) fail with the power supply short to output and burn the speaker. And in my previous post (that you didn't answer) I did ask genuine. Chinese does NOT equal genuine.
