trying to resurrect an Orion 2150GX after massive short
Hi everyone, as per title, I need some help in trying to resurrect the amp. was working perfectly until, unfortunately, the speaker terminals, on the speaker side got loose and shorted. massive fry up the PWM session, 3 fried original 2N6488. anyway, opened it up and found more were not in good shape and once removed the bars, I had to go full strip down.
Out of the total 25 2N5488 I could only test 8 good and out of the 2N6491 1, most of the latter broke when trying to remove from the bar, despite using Perry's suggested method. to cut the story short, I removed all from the PWM and output, including the SF163/A and the LM317T/337T. went to local electronics shop and got BD911 to replace the 2N6488 and BD912 to replace the PNP 2N6491.
SF163/A came out good so put them back.
MSPA06 tested on board and all look good.
MCT2V octocoupler also tested on board and seems good. anyway, I wne on and read in the past I could add power with just a barebone structure in place, so I put back the BD911 driven by the MSPA06 for the gate drive and 2x BD911 per rain in the PWM, SF163/A and powerd up with a 12v bulb as safety.
Didn't smoke anything and I got VAC out of the secondary of the main toroid and VDC aout of the center pin of the SF163/A, I only got 1.7 VDC on the SF163 and -2 VDC of the SF163A, this using the driver output GND as reference. also, REM doesn't seem to do anything as soon as I power up the amp goes on.
I tried Perry's trick or desoldering one leg of the thermal protection, but that doesn't seem to change anything on the REM circuit. so I checked again the octocoupler on the left, the R and the diodes, and the 2 MPSA06. all seems good by the reading when checked in diode mode. i have drawn the schematic as best i could, and i ended up with the exact same diagram of what was posted here already. i need some help troubleshooting this nice amp. I know and I'm sure there are better sounding amps out there, but I just love the form factor, the tone, and the looks.
i have a switch to enable REM ON/OFF and I can see 12V or 0 when flicking it.
Power led also not lighting up
original schematics credit to 90scaraudio from this thread: https://www.diyaudio.com/community/threads/orion-2150gx-repair-help.220408/
The self-oscillating amps didn't like resistance in the B+ line and most won't power up unless powered directly without limiting. If you want to protect it, clamp all transistors tightly to the heatsink and insert a 15 amp fuse in the B+ line.
Use high temperature silicone rubber tape instead of the double-sided tape.
ok, with a 15A fuse on the B+, applied power and nothing smoked.
readings:
REM ON
Pin 2 of SF163 +39.7 VDC
Pin 2 of SF163A -39.7 VDC
REM OFF
Pin 2 SF163 +0.9 VDC
Pin 2 SF163A -0.9 VDC
are these expected values?
ran for about 10 minutes to double checks reading and not heat building up on the transistors
yes, read all about it in the last couple of days and bumped onto this advise. including metal brush to remove the original from factory 😉
sorry Perry, just to be sure we are on the same page, the +-39 VDC were measuresd at the pin 2 of the fast swtiching dual diodes, after they have rectified the AC coming from the secondary of the main toroid.
did not measure the V on the driver winding
UPDATE: in a nutshel, BD911 is not a replacement for 2N6488 in the PWM.
I had 8 left from the tsunami, put them back 3 each rail, 1 as gate driver and BOOM, back on the game with +34.4VDC at the Zener (cathode side), 32.5 after 10 minutes on idle.
Next issue now, with the BD911 it would feel the REM ON/OFF, now it won't.
Ideas? i checked already the thermal sensor and OL in diode mode
