XXV Sampson power up issues
voltage applied from same source as 12v power, which is a 12v 50a regulated power supply which is inside a finished wooden box with a pioneer head unit, stinger volt meter that was calibrated with my extech dmm set to 13.9v. 12v power to amp has jumper to remote terminal with toggle switch
i recently replaced all KTA1072/KTC3228 driver transistors(3 banks of 8). There are no supply, output or rail Fets on the board. I apply power to the amp, the output relays click on. I have a Hantek HT6022BE PC based scope, DS201, and DS203. I'm trying to get the amp back to working order after being dropped to my floor pan during an install. It slipped from my nephews grip and fell about 2-3 inches. Still installed it and didn't power up. I just tested the PS drivers
That's OK.
Connect it across the gate and source terminals and while it's connected, check the gate signal .Confirm that all are the same.
If you mount it on a piece of header (or similar) and put a small amount of back force on the header, it will make a good enough connection to check them without soldering.
The waveform should look something like the attached waveform. Use the scope in the same settings, and DC coupling. Align the trace to the reference line before starting.
if we're talking about the input drivers, which legs would the gate and source be? On the datasheet I see emitter, collector, and base. Sorry for any confusion. If you want me to test the supply transistors I will have to solder them to the board
same as in post 137. Scope set up properly, I'm not sure what "2.5 major divisions" is but 10us/5v along with 1x on scope and probe are good and trace is set above 0 ref line. I get the same measurement on the scope and the PS driver IC's for those PS Fets locations give me the same result also.
