There are a variety of free internet applications that do this.
https://vocalremover.org/
https://www.lalal.ai/
https://voice.ai/tools/vocal-remover
https://x-minus.pro/ai
Thank you.
I tried the first one and it's quite good.
But I wanted to build a contraption. Let's see if I can.
It was done by analog before those, so it's possible, at least if the voice is center mono.
https://www.elektormagazine.com/labs/vocal-remover-circuit-no-chips-passives-only
I've attached the sheet for the NS8002A module.
The circuit on that pdf shows the first amp stage configured with a 20k input resistance. It is actually marked Ri and that sets the input impedance in that configuration to 20k. The 0.39uF (all these caps are coupling caps, decoupling are the caps across power rails)
So 0.39uF and 20k form a high pass filter with a -3db point of approx 20Hz
A 1uF ceramic will work fine and lower the -3db point to 8Hz. For high end audio we would more likely use a film cap but ceramic is perfectly OK for this.
One last one (hopefully) . . . should I add a coupling cap to the output of IC2. If so, then would 1uF be OK?The circuit on that pdf shows the first amp stage configured with a 20k input resistance. It is actually marked Ri and that sets the input impedance in that configuration to 20k. The 0.39uF (all these caps are coupling caps, decoupling are the caps across power rails)
It is like Rayma says, coupling cap sizes are determined by what it works into and what sort of lower frequency cut off point you want.One last one (hopefully) . . . should I add a coupling cap to the output of IC2. If so, then would 1uF be OK?
If the NS8002 board has a coupling cap at the input then that is all you need. If you add one after IC2 you must sure any DC bias paths remain intact such as the one to IC3 inverting input (with extra resistor as I showed earlier).
Yes, I added the 10K resistor between IC2 and IC3's invverting input.
The NS8002 spec sheet shows a 0.39uF cap before a 20K resistor upon input.
Would my adding a 118nF cap after IC2 be a problem (f=70Hz, R=20K)?
The 0.39uF and 118nF would appear as a single series cap of 90nF would give a -3db point of 88Hz if run into 20k
i've got a bunch of 474nFs which i'll string together. the PCB will get a little crowded but that'll do. thank you!
474 is 0.47uf.
(474 is four and seven and four zero's with the answer in pico farads. So 470000pF is 470nF = 0.47uF
Did I write something incorrectly? Four 474nF caps in series -> 118nF, and the rest is arithmetic. i came up with 87.5 Hz.
Things sometimes get misinterpreted or assumed (by all concerned 🙂)
You mentioned a bunch of 474nF caps which would be an odd value. I wondered if you knew how the values were arrived at from the markings. 104 would be a 100nF for example.
So I said 88Hz, you got 87.5Hz. Those are just rounding errors.
I took this face value. 118nF (an odd value but you didn't say it was four 0.47uF in series ) after IC2 will appear in series with this one:Would my adding a 118nF cap after IC2 be a problem (f=70Hz, R=20K)?
My observation is those opamps aren't designed for audio and have too low a GBP. Also they are micropower at 200µA supply - serious low distortion audio opamps tend to be in the 2mA to 4mA supply current range in order to be fast enough to give low distortion at high audio frequencies.But aside from what errors you might uncover I have a question about grounding as pertains to the three ICs (MC33171N [spec sheet also attached]).
Mooly,Things sometimes get misinterpreted or assumed (by all concerned 🙂)
Please have a look at Tillotson's #36.
I looked at the LM4562 and it certainly appears to be a better amp.
But there are different flavors of "high fidelity." That is, while I certainly want to avoid distortion I am not driving a 60 watt speaker hoping for concert hall quality.
Do you think the MC33171Ns would still suit me?
-Roy
I think so on balance. While Mark makes a valid point, the 4562 (and many others) while certainly 'better' are also devices that demand much more care in layout and implementation. Your 33171's should be docile to implement. You could equally use the common 741.Do you think the MC33171Ns would still suit me?
- Analog Line Level
- Question about Ground of an IC
