MarkAudio Okapi - Alpair 7MS build
I wanted to share here my experience of building the Mark Audio Okapi with Alpair 7MS designed by Scott Lindgren. I was looking for a relatively compact (i.e. narrow) loudspeaker that I could use in my home office. The plan is to use it with an Audio Note Kits "Virtuoso" PP EL84 Headphone/Speaker amplifier that I built a few years ago. I am currently using a pair of Fostex FE83sol in tiny cabinets and I wanted to see if I could do better than that. After reading many posts in this forum I decided to give a self build a go.
Since I do not have a workshop I ordered my plywood (18mm baltic birch) pre-cut online from cutmy.co.uk. I could even specify the circular cut-outs for the drivers and the reflex tube. Here is what came in the package:
Thanks. I am still working at it and I will post pictures here of the different stages. Next stage for me was the chamfering of the holes for the driver. I used my Dremel tool for that. The results turned out a bit irregular.
A more interesting challenge was the second layer of the baffle. The inside of the enclosure is quite narrow, so a 45deg chamfer is not possible towards the sides. I first glued the second layer baffle to the outer layer.
And then used the Dremel tool again. The sides of the holes became quite thin.
Reactions: Vix
A few more steps towards a working Okapi. Damping is glued to the inside. I got the damping material and glue from KJF Audio in the UK. Word of caution: This glue is the stickiest stuff in the universe and the coated damping material needs to be handled with care (and preferably rubber gloves)!
Next step (after soldering the wires to the terminals) was closing the box, sanding and applying some wax. One box finished:
one more to go...
Looking good.
@kjf sells some neat little crimps, that work well to terminate the cable onto the driver and the terminals (Yantzen ones anyway), as I dislike soldering as I am terrible at it.
If you can possibly help it don't listen to them for at least a few days, they really do take 50-150hrs to open up.
Thanks. The speaker have been completed (and listened to 🙂). I learned to solder when I was a teenager and I can still do it, but thanks for the tip. I have installed the speakers somewhat unconventionally in my bedroom/home office. I am aware that the location might not allow them to be used them to their best abilities, but that's where they need to go. With a bit of bass EQ in Volumio they seem to be doing fine.
img_20250511_115148_hdr-jpg.1471441
Reactions: Klimon and MalVeauX
