AmyAlice SLIM - SMPS filter
Had a very busy day, here it is. FB is ferrite bead, FTC is feedthrough cap, led r is calculated based on voltage (and current trough led depending on how bright you want it( so no value. Bit ugly but tired to do CRIF and bom designators 😴
  • Thank You
Reactions: Julian RO and TNT
Wanted to share a couple that I built. First one was to filter from a SMPS to a balanced buffer for an amp I’m building. Then I built a double filter box for a phono preamp and an audio interface for a record ripping setup. Ordered like 20 PCB’s so planning on putting them on everything!
Thank you for the design!
