D-Noizator: a magic active noise canceller to retrofit & upgrade any 317-based VReg
That's the startup swing, it's normal. You could also try a 3.6R or 3.9R for R16 in the negative version. For the higher gain versions that resistor was usually needed in my case but in this lower value. 22R is on the high side, don't think I ever used such a high value.
I confirm what Trileru says: the behaviour is normal, and is a result of a trade-off between the VLF correction ability and the capacitors values. If you don't need VLF operation, you can reduce C8. Increasing the 220µ would also be possible, but unpractical unless you absolutely need VLF correction
Not really, depends on the gain of BJT with same R3/R18 of 180K. Positive rail has higher swing because of higher Q1 collector voltage. If you increase R18 to 330K for example then the negative startup voltage swing will get higher. At least for the CCS version, not sure how it will work out with R2/R17 instead of CCS.
Just out of curiosity, why doesn't the LM337 show the same behavior?
The 337 is a different circuit, designed by another person, and although it was supposed to have a complementary behaviour compared to the 317, things turned out differently.
The voltage on Q3 is suspect: check the value of the 180K bias resistor, and the polarity of the 22µ capacitor (+ side connected to the base)
The LM317's series pass device is an NPN transistor operated in common collector mode. However the LM337's series pass device is not a PNP operated in common collector. The LM337 is not a mirror image complement ("dual") of the LM317.
_
Reactions: jackinnj
You nailed it. I messed up the resistors (need new glasses) and used a 1K8 instead of a 180K. I completely torn the circuit down and rebuilt it from scratch, double checking all connections and values.
Now I get -1.75V at the collector pin of the BC327-40 for a -12.1V stable output voltage (2k ohm load). If I change the output voltage, this value doens't change much. For -5.3V I get 1.57V at Q3 collector pin.
This is a general question related to this entire thread. With notable exceptions where the circuit designer specifies a specific ESR. Am I free to substitute Aluminum Polymer capacitors for the traditional aluminum electrolytic capacitors? A brief read has uncovered some cost and size advantages.
Here's a brief summary I've read.
Comparison of Polymer vs. Traditional Aluminum Electrolytic Capacitors​
Now for the million-dollar question: Are polymer electrolytic capacitors or traditional electrolytic capacitors the better option for engineers? The answer depends on your design needs, as there are unique advantages to each.
Pros of aluminum electrolytic capacitors:
  • Higher voltage ratings available (up to 600V)
  • Way cheaper pricing (for the same capacitance and voltage)
  • Better leakage current behavior than polymer
Pros of polymer electrolytic capacitors:
  • Lower ESR/higher allowable ripple current
  • No dry-out behavior (unlike aluminum capacitors)
  • Higher expected lifetime/load life
Dan
