OpAmp driven diamond buffer amplifier
I've thought using terminal 'tag' strip would make a nice build, but maybe its more suited to valve circuits due to components being larger.
There is also point-to-point boards that I like to use for simpler circuits (I like for prototyping):
Reactions: Ixnay
I just tried it with a modest NE5532 and it performs like a champ. Sadly, I don't have any BD911/912, otherwise I would have build one on perfboard this weekend. Maybe I have something similar sitting around. THD at 0.0005% isn't bad for such a simple little thing.
View attachment 1441345View attachment 1441346
Be careful with this. NE5532 have max. +/-22V supply voltage. Those BD911/912 seems to be well available here .... could be interesting later.
Me too, i rarely pay close atention to the exact transistor model, i wanted to use the mje3055/2955.
This is what a prototype is supposed to look like. A total mess. 😀
So, not surprisingly, you design works. At least it amplifies a signal at >0.1% THD (probably much less) without letting out the magic smoke. So far so good. A few more sanity checks and then we’ll see how it does driving a speaker!
I declare my Sunday experiment concluded. It plays music and actually sounds quite nice. I'm using a NE5532 and a 47p Miller capacitance. could probably get away with less. It might be fun to try a few other opamps, such as the TL072 and LM4562 that I have laying around. The output transistors are TIP35/36 which aren't exactly known to be great audio devices, but it works fine. Such a high power transistor is overkill for the first stage. Maybe a BD911/912 instead?
I'm running it at +-18V and it pulls just about 2W at idle and barely gets warm. The bias current spikes for a few seconds after power on, but settles nicely.
I might build one for my patio speakers, but I'll probably add some overcurrent protection and reverse polarity protection.
Overall a neat little amplifier! Thank for posting @No ideas
Reactions: twitchie and stv
