Something like this:
https://calvins-audio-page.jimdofree.com/projekte-projects/phono-vinyl/all-jfet-se-phono-1/
It's inverting and therefore I add an inverter behind the mu-follower. If you like, I can share the schematic, but it's off topic, I think.
I'm no expert, but I thought a SRPP don't use the capacitor to drive the upper FET?That is not mu- follower , it is one srpp stage
Yes I do.Do you think two mu-follower with reduced gain are a better option?
Patrick
Maybe you are right, I don't know. I thought the mu-follower has this capacitor driving the upper gate and the SRPP not.Well you should trust Calvin on that 🙂
Besides you can use 100...220nF there instead of 68 uF.It is used mostly for coupling the RIAA network.The dc bias is fixed and external instead of autobias and you don' t need so much coupling capacitance.A mu- follower needs a higher value source resistor and the RIAA network would have been placed at the source of the follower transistor.
Thanks for the simulations and the explanation/recommendation. In fact I can have higher voltages if necessary. I'm still in the design phase.So what is the design objectives ?
Gain -1, Single Supply 30V, NJFETs, Zero Global Feedback (ZGF) ? Preferably low distortion for 4Vpp ?
For a simple circuit with ZGF, a phase splitter followed by Source follower comes to mind.
But the supply voltage sets some limitations to the phase splitter.
The JFET sees the fully 4V swing at maximum input.
So it needs at least 7~8V across D-S at no signal.
The drain resistor has to be a touch higher than the source resistor to be truly inverted unity gain.
So they should get ~6.5V and ~6V respectively.
The bias is determined by the resistor values. Let's say 4mA as a starting value.
The source resistor is then 1.5k, and 1/Yfs of the JFET is roughly 40R.
That basically determines the amount of distortion at the output.
For 20V, H2 is about 0.05%, and H3 ~10x lower. Tube sound.
At 30V, the values can be halved.
It is known that some BJTs can have low Vce_sat and little Early effect.
And the gm is higher than JFET at the same bias.
As can be seen, the BJT circuit with 20V supply can have half the H2.
Which one would I choose ?
If I can have 30V, I would use NJFET, as H3 is 10dB lower than the BJT version.
If I am stuck with 20V, then no choice but to use BJT for the splitter.
BTW, you don't need to buy expensive 2SK170, and for sure not LSK170.
Just wire a 2SK2145GR in parallel and use as K170GR replacement.
www.diyaudio.com/community/threads/njfets-for-source-follower-applications.329131/
Patrick
Yep you just use a same old typical known op amps for low noise, gain and RIAA
Mystically magical high distortion discrete circuits, don't do much but make distortion.
So comical from small signal to high current to speakers. There is so many lost concepts to engage in.
Complicated circuit. Aside from power supply decoupling.
1 cap 2 resistors = done Anything from .001% THD to .00006% little bit below -60 dB LOL!!
What is next to add to Overthinking longer solutions for easy problems a 18 month permit process to start building nonsense audio.
Thank you for your fruitful contribution to this topic. Again, I know that an operational amplifier can be ways better and I'm used to work with them in other circuits. And yes, I know that there is a reason why most circuits today are based on integrated circuits and the manufacturer of them had done a great job providing great solutions since 1958.Complicated circuit. Aside from power supply decoupling.
With two mu-follower I have a lot of gain and need a feedback to reduce it, or do I understand something wrong.Yes I do.
Patrick
I'm pretty sure you already knowsThat is not mu- follower , it is one srpp stage and a follower buffer , it' s using a very passive riaa network as well.I looks like highly nonesensical to me, but I' ve done way more stupid things in life so who am I to judge it?
You could go active like this although the usual configuration is with a passive riaa network in between stages.Just replace tubes with jfets and their usual lower resistor values to go with transistors:
OK, here is the story. I settled on a 12AX7 12AY7 combo. It is giving me all the RIAA gain I need and then some.
The unit sounds very good. I currently am listening to an Eddie South jazz record in mono over my test speaker. Very crisp clear audio and dynamics. Over the past couple days I tried a cascode. I also tried the same configuration as now only with two 12AX7 tubes and a cathode follower. Both trials sounded so dead compared to the configuration I have now, especially the cascode. The cascode sounded so compressed, dead, and transitory.
I am having a problem with my woofer...
https://www.ti.com/lit/an/snoa620/snoa620.pdf?ts=1737831833497
where you can find this type of amplifier on page 5. If I got you right, you mean something like this
https://www.valvewizard.co.uk/mufollower.html
without the extra DC offset at the upper gate?
I am not a tube guy.
But I guess you are using something like the Ultra High Gain Audio Amplifier in P.5 of TI AN-32.
Then Av = Yfs / Yos / 2 of the lower JFET
If you choose a JFET like MMBF5456, you will have a gain of 50 or less.
You can further reduce the effective Yfs by adding a source resistor to the lower JFET, right ?
http://www.geofex.com/article_folders/foolwfets/foolwfets.htm
It also helps to give you a more manageable bias current.
The upper JFET and the source follower don't have to be the same as the lower JFET, right ?
Patrick
Patrick
"I looks like highly nonesensical to me, but I' ve done way more stupid things in life so who am I to judge it?"
Exactly! Before dismissing other´s designs with stark wording rather think about them in depth.
It´ll prevent You from appearing arrogant if not foppish, especially when You seemingly haven´t ´got´ the reasoning behind the design decisions.
back to #36: I came up with these circuits after having seen Alex Nikitin´s designs for Creek (OBH-series) and his contributions here at DIYaudio.
My part was basically having translated his bipolar and hybrid-bipolar-JFET designs into a JFET-only world.
Along this process it became quickly clear why the cap needs to be large ... at min in a medium 1-digit µF range.
So, yes, it makes sense.
As for the gain=-1 buffer application: You could omit with it by just connecting the pickup inverted .... or, if You don´t believe in ´absolute phase´ 😉
jauu
Calvin
jauu
Calvin
That will be an option as well and provide best possible THD. 🙂As for the gain=-1 buffer application: You could omit with it by just connecting the pickup inverted .... or, if You don´t believe in ´absolute phase´ 😉
The question is whether one stage amplifier with say Gain of 500 is lower in distortion than two stages with gain of ~22 each.That will be an option as well and provide best possible THD. 🙂
Patrick
Hi @Calvin. Thanks for joining here. As already said, I like you design proposals and you are right, this high value capacitor is necessary and the performance is great, at least for me.
What do you think about the difference to SRPP and/or mu-follower. What's the officialy definition. I guess it's driving of the upper device?
https://en.wikipedia.org/wiki/Push–pull_output
Sorry, but this is wrong. Have you made a calculation?The difference between 220nF and 68uF is only that the RIAA precision gets microscopically better.
Here a quick example. It's not the same circuit, just quick and dirty with some random components and a riaa network. Notice, that the capacitor C is places at another position. The three results are for 220n, 3.3u and 68u.
This can be true, right. And I prefer film as well. But if you like a totally flat gain the big cap is one thing to check. For sure, you also have to check the new issues, the elco may generate.Ok , make it 1u which is kind of the max limit of resonable priced film capacitors
- Design & Build
- Electronic Design
- Unity gain inverting amplifier/buffer
