Despite having the exact same tweeter you would never know it in a million years, because they sound completely different.
Well, how many times have you heard a speaker with the tweeter not actually functioning? It may take us a while to even realize it's missing. We focus so much time and money on tweets, but the sheer amount of energy and music they produce is really relatively small, so I 100% believe you.
I think there is an underlying theme here. By placing the edge very similar to the drivers width, you have approximately no edge diffraction to deal with.I think absolute dimensions do not matter at all. Only relation of transducer size to baffle size matters for the secondary sound source that forms at the edge. 25cm baffle would make problematic edge diffraction back wave for 10cm driver, but for 25cm driver it would be fine.
This easily understood. I think that with a large enough baffle you also cause diffraction to not be a major issue.If baffle is much bigger than transducers, then it could be problematic sounding. When baffle is no bigger than transducers it makes very little problematic secondary sound source, because the sound that emits at the edge is almost the same as the driver sound, only few centimeters late and in midband basically no different than sound emitting from the cone itself.
Remember that as the distance between sound sources increases (delay increases), the comb filtering at higher frequencies will begin to average out (but it IS still there). The problematic destructive interference will be lower in frequency. Low enough frequencies will simply not care about changing from half-space to full-space radiation. "100 Hz doesn't care about your baffle edge diffraction."
So what width would be enough and enough for what situation if aiming for wide baffle. When will there not be any driver induced directivity at 2khz? Approximately 6.5" is what I see. A crossband containing 2khz is definitely possible with a 1" tweeter. I believe that less work is needed to treat the edge when the dimension is large enough. The lesser deviation caused by edges at large dimension suggest that lesser technically perfect treatment needs to be implemented in order to achieve desired effect. Since ~423hz doesn't care much about the 90 degrees angle, a round over that satisfied the 2khz area would be plenty as the strongest note exist at whole wavelength not its harmonics. So if a certain roll over satisfies diffraction at a ~6.7" baffle, it would be over kill with the 32" baffle.
Less than a >1" is needed for a proper rollover of a baffle of ~6.7" wide, to deal with ~2khz so a baffle of 32" should be fine with the same. Thats my thought at least, I cannot simulate this to test the theory.
I've been struggling to settle on horn/driver combinations to use atop my pair of sealed Altec 416-8B midwoofers. The most likely candidates are SB Audience 65 CDNT, Yamaha JA6681B, B&C DCM50 and Radian 745neoBe.
Regarding the DCM50, I seen posts such as here https://www.audiocircle.com/index.php?topic=169189.0
https://community.klipsch.com/index.php?/search/&q=dcm50&search_and_or=or where it seems as if others like me also have struggled with the dilemma of owning or wanting the benefits of high res horn speakers but troubled over how your less than pristine recordings will sound on them.
Indeed, so many of my treasured 60s pop and soundtrack music-many of which otherwise respectably recorded (fairly low noise and distortion)-were then deliberately mastered with lots of compression. No doubt this was done to make them playable on cheap vinyl players, or even the SOTA turntables of the day.
But in Troy Crowe's review of these drivers, please take time to watch this video entirely from 17:15 to the end.
Notice that during his listening test ratings, Troy gives the DMC50 a less than 10/10 rating for dynamic range. My question is would the B&C DMC50 be a much better choice for playing our over compressed recordings than one with more higher sensitivity, and thus more dynamic range, such as the Radian 745neoBE?
Comparing basic specs:
https://www.bcspeakers.com/en/products/hf-driver/archive/dcm50-8
https://www.usspeaker.com/radian 745neoBepb-1.htm
And might the DCM50 also be a better choice for playing compressed recordings because it uses a "composite" or paper diaphragm, rather than a beryllium one, like the 745neoBE?
Embedded compression and diaphragm composition have no relationship to eachother. Whichever material sounds ‘less worse’ to your ears…..well….that’s the one to get.
On a side note…..I’m pretty firm on the opinion that the word euphoria and compression drivers don’t belong in the same sentence……maybe even paragraph.
the B&C DMC50 will also goes down to 400hz easily so you can have a 400 to 8K pretty clean ..
Exactly the intended yardstick; with such troubled recordings how else to go about driver and horn selection? And if I’m not mistaken, the Altec 416-8B midwoofer’s polar response and high sensitivity won’t work well with direct radiator drivers.
I gave my builder Troy Crowe access to these recordings via my Google drive (uncompressed WAV files of CD tracks from my collection), which I’m hoping he’ll have time to review. Meanwhile, I reasoned that at this thread someone might have actually heard the DCM50 with compressed recordings and could therefore possibly recommend it or even a more appropriate driver (for compressed recordings) for building a three, though ideally, a two-way system.
Which of these biradial horns might work best for the DCM50 and the sealed Altec 416-8B?the B&C DMC50 will also goes down to 400hz easily so you can have a 400 to 8K pretty clean ..
https://josephcrowe.com/products/3d-cad-files-horn-no-1994-es450-biradial-for-jbl-2446-2-throat
https://josephcrowe.com/products/3d-cad-plans-for-es-290-biradial-horn-horn-no-1670
If not, then something very different like the JMLC AH-340?
https://www.azurahorn.com/azurahorn_horns.html
my system is pretty similar than yours , i will say the biger the better if you want to Cross Low i have a 240hz LMH Horn and cross at 450hz with a TAD 1601b ..
IF I was looking for a euphoric driver to build a system for my very good to excellent sounding CD recordings I would simply build Pierre's system; see posts 15,266, 15,276.
https://www.diyaudio.com/community/threads/beyond-the-ariel.100392/page-764
Only difference would be that I would use a pair of Altec 416-8B midwoofers in sealed 4.2 cu ft, using Lynn Olson's design.
https://www.diyaudio.com/community/threads/beyond-the-ariel.100392/page-767
While Pierre reported that most of the ~ 50 WAV files of CD track rips off my Google Drive sounded compressed, he said that about four or so blew him away. 😉
I wouldn't have to theoretical design knowledge to decide on that for the Altec midwoofers. I would have to leave that up to Troy who has my midwoofers and ran this test on them.
They were cloned from another's design for me by Jim Salk. https://www.salksound.com/ But the one thing I fear that may badly impact success is that in order to ensure very low IM distortion, the DIYer set the box size to 3 cu ft, so they only play down to 70Hz.
I do have two pairs of these subs. https://www.rythmikaudio.com/F12.html . Jim Salk assembled them with his own sealed cabinets.
https://www.salksound.com/model.php?model=Rythmik+12+Subwoofer
I'm hoping that, worst case, if I use all four subs at the right crossover points-and by using this multichannel DAC
https://www.merging.com/products/interfaces/hapi -it would help to minimize coloration.
I have a question or two about this statement. It's of interest to me both out of general curiosity, and more specifically because I'm about to build a big on-wall system in my rehearsal studio. As in, sufficiently big that it might as well be regarded as an in-wall system.Sadly, along with the diffraction, so to goes the imaging……the surface area draws attention to its own presence in the 3D space and all is lost. I’ve mixed in plenty of rooms with soffit monitors and while they’re terrific for the analytics, I’d NEVER choose this configuration for personal enjoyment.
I’ve been repeating this for decades now…….narrow baffle speakers out into the room away from walls rule unequivocally with minor room treatment. ....
My main question is... why would this hurt imaging? What mechanism is at play? Is an in-wall missing something good (implying we want some extra localization clues from the speaker edges ????), or is something deleterious happening?
A soffit-mounted, or truly smoothly integrated in/on wall speaker could have little or any diffraction at all. Wouldn't a complete lack of time-delayed re-radiation from cabinet edges improve imaging?
I'm wondering if the bad imaging you've heard from soffit-mounted monitors might have been due to one or more of the following:
1) The speaker design. Perhaps large format, multi-way systems with the (large drivers, possibly in multiples) very spread out horizontally, maybe not very point-source-like to begin with?
2) Maybe the soffits aren't / weren't all that flush / seamless, or have other architectural features near them (like big windows into the studio?) that cause some of the same problems that a cabinet edge would?
3) They were mounted too far above ear level for a natural-sounding presentation?
4) There's a giant mixing desk sitting right between you and the speakers?
I've certainly seen all of the above, both in person, and in an awful lot of photos accompanying articles in Mix, etc.
Or... if there really is an inherent problem getting good imaging with in-wall speaker placement, could it be that having front-wall reflections coming from the same plane as the speakers is the culprit?
I could see the potential for that being aurally confusing. If so, perhaps diffusion or absorption on/around the speakers could help.
Speaking of Altecs, please look over my posts on this page.I've tried repeatedly, but short of my own DIY horns, mildly tweaked Altecs remain 'best of the rest' overall for recorded music, especially 'live' ones.
https://www.diyaudio.com/community/...gh-end-midrange-you-have-heard.405952/page-14
As I can't see myself scraping those 3 cu ft sealed cabinets and starting over with ideally sized ones, like Lynn Olson's building,
how successful might my multi-sub idea minimize upper bass coloration, or other problems?
In a nutshell?.........i really don't know as i have never taken the time to analyze further and test......but IME there NEEDS to be that free air space all around the speaker. Maybe it's the elusive 'power response'? It's been my argument that a pair of capable 2 way bookshelf types out in the room with a few subs can take down monkey coffins costing 100x the price........I have a question or two about this statement. It's of interest to me both out of general curiosity, and more specifically because I'm about to build a big on-wall system in my rehearsal studio. As in, sufficiently big that it might as well be regarded as an in-wall system.
As yet another fortifying example....last year i treated myself to a pair of Magnepan LRS plus for our country side home........its a chalet style place not too big but high ceilings.......and for all of the sonic shortcomings and obvious uneven frequency response, these little panels placed 5ft out into the room an paired with 15" sealed sub run mono up to 100hz is just nirvana for engaging with my favorite music.
As an engineer, my focus has always been on phase relationships.....my ear has been permanently scarred by the methodology while mixing...hence the modified KEF Q150 monitors are my goto for the past 3 years. I can and have mastered before.........but it's NEVER a good idea to be involved with your own mix....too much bias to be constructive. When mastering, imaging moves more into focus along with overall tonality and some smoothing via compression and surgical eq. In these instances, i really prefer a very well treated room purpose designed OR a WMTMW type of speaker. Same rules apply for me though.....out in the room and a minimalist mastering desk and a rolling chair to kick back into the space and listen.
Using in wall speakers in a controlled room gives GREAT imaging! You precisely hear phantom sources in a way as you have the impression you can "grab" the sound when eyes are closed. You have the stereo width fron the original recording and easily get wider sound as the speaker base distance - when it's in your recording (out of phase signals).
But - it's not an immersive way of presenting the "imaging" as you can have in a reverberant room! You are not "in" the sound. That's not what Stereo can give.
It's room reflections with the right timing that can give you this effect. For most listeners it's not about having correct imaging - it's about having fun and enjoy the music. And that's totally fine - music is here to give emotions and a good time.
@tonyman108 Your plan for your rehearsal studio is good! You save a ton of space, have precise monitoring at the listening spot and good audio through the room. Don't underestimate the SPL you need! It's nice to also have the monitoring during rehearsal sessions over the main system and you need a lot of headroom during recording. Do you have a thread about your build here?
I have a on wall speaker system in my listening room and also a rehearsal studio room here, both well dampened and I get very good results. None of the typical "boxy" sound of a small room with low ceiling. It's doable but you need the right concept.
There is nothing wrong with the emotional connection through stereo imaging alone (minus potential in-room 'spaciousness'). If anything, it's improved that way compared to the average room contribution, although some manage to get a neutral room contribution that doesn't harm imaging.
It's not easy though.
With regard to mayhem suggesting speakers need space around them, I disagree when they're successfully designed for the purpose of half-space mounting but I'd agree it's possible if a speaker wasn't compatible with that mounting.
One example of a source that must be kept in free space is a LeCleach/Tractrix horn, and there are also many cases that are far less obvious than that example.
I like the metal cone Mark Audio 10.3 and 7.3 a lot. But i also like the scanspeak 10F/8424G00 (with doped fiberglass cones) or the SB Acoustics SB12NRXF25 (natural fiber) and MR13P (papyrus fiber) a lot. It's not so much the cone material but how it is made and how well it deals with avoiding or damping resonances in the frequency band. Both hard and soft cone material can do it right actually. It also helps if the driver is used in a way that it's not stressed at all (by choosing the right frequency band and not pushing it to it's limits) to avoid distortion.
And off course this only works if the rest of the speaker is also done right, phase alignment and good dispertion are also important,
Sorry to necro the thread, but seeing what @tmuikku , @YSDR , @camplo and others said here, it seems you might be able to help me.
I'm thinking about building Anthology II speakers, which usually have 1/2-3/4" roundovers. Since I have access to CNC routing, I could make much larger and more complex roundovers:
Would this be too much? I worry that the different lengths might affect each other and that top mid might refract from the bottom mid roundover which is angled differently towards it. Would this design help me? The mids are placed in open rear tubes and work somewhat like dipoles here. And would the shape of the top be a problem?
This roundover goes from 30mm radius on the woofers to 90mm radius in the tweeter and then back to 30mm on the top. Should I do it or do I risk breaking the desired sound?
Hi, I think the roundovers are fine as such thinking only tweeter response or mid respons. But I have not played with MTM speaker so I do not know what the response is in system context and how to optimize for that. It seems ok though on a quick imagination simulation. In general, the shape and size of things and drivers and all depend on what you want the system response to be, so the system response is the goal, not just some single detail like roundover radius. You'd want to align most aspects of a system toward the main goal, good system.
I phrase the message so because: Mid tubes open to back makes great path length difference and the response is not dipole but something cardioidish with all sortsa resonances due to the tube. Together with what MTM makes for system response, and the fact that woofers and tweeter aren't specifically also accompanying gradient mids I suspect system response is gonna be somewhat random result. Which might be fine, just something unconventional and I see no reason why would you want to make system like that. If you want to use the mid driver back side sound somehow, you should make the top portion of the box a proper passive cardioid or proper open baffle dipole thing, or close the tubes from the back so that the mids are in closed box effectively.
To me it seems you have learned details of various concepts but not the big picture yet how to make it all work together toward one goal system response that works within our room and what you want to hear, the context you plan them for. And as you are now learning aesthetics and manufacturing are also very important aspects of a project so it's always a huge task and juggle. So, keep on going, you'll learn a ton doing, do what ever feels most important as everything cannot be learned at once with a single project! Have fun, keep it interesting to you!🙂 It'll likely sound just fine and make a ton of great experience, just because it's a great effort.
@tmuikku thanks a lot! The main design is not mine, it's the Anthologies II speakers by Jim Holtz and Curt Campbell. They started the open back mid design with their Statements and carried it over to Statements II, Anthologies, Bordeaux and finally Anthologies II - people seem to love it and that's why I decided on this design. This sadly also means that I don't possess the required knowledge to change it sufficiently to make it into a cardioid. All I'm trying to do is make the best of the design I have with tools available for me - CNC. That's why I'm asking about these big concave roundovers. Do you think it won't hurt if I would do them without changing anything else about the design? Or in this case would you rather stick to just standard small roundovers? I am not knowledgeable enough to change the mids to closed back or cardioid without breaking the sound 😉 And I do think I'd like to try the open mids. So, should I risk these roundovers? 😀
Hi, I am not familiar with these projects so I cannot comment further. If it works for them then it should similarly to you.
Oh yeah the roundovers will change the response so you a crossover that is made for no-roundover situation isn't ideal. I'm assuming you will measure and make crossover for what ever it is you've built anyway so this is not an issue as such. However, it's likely a passive crossover speaker and I do not know how much of a difference it makes in reality, whether you need more or less parts or just change some values, or does it really matter, so this is something you'd need to figure out.
If you have no measurement capability and intent to change drivers and xo anyway, then perhaps don't change the structure either, it affects as much to the response as the drivers or xo. Although, if you never measure what you build the result is random ( there might be mistakes ) so also the roundovers make random difference and would not matter other than visually 😀 which ever is your logic to approach things. In the end, ear adapts quite well and small differences don't bother that much unless you always critically listen and have something to compare to. Also visuals are important and valuable, also the process of designing and manufacturing, so go ahead.
edit. did quick search for information about Anthology II and there isn't much other than this: https://www.speakerdesignworks.com/anthology-ii
Since I have not heard the speaker and have no possibility to all I can use is data and visuals, and there really isn't enough information available with quick search that I could comment anything on the mid tubes for example. I've got quite critical eye to marketing and commercial stuff, so I'm inclined to say mid tubes are just marketing to differentiate from all other similar boxes. Straight face is also due to business reasons, it's easy and cheap to manufacture, also looks good and considering most people listen quite far and in random acoustic environments it's not worth it to optimize for diffraction on such commercial speaker.
The above is my opinion on things with very quick overlook so I suggest you should go for what ever feels relevant to you, because that keeps you motivated and keep on improving things and is the only way to good sound if you are looking for one.
- Most euphoric high-end midrange you have heard?
