Clon C-3850
Thank you for your clarification @hifiamps . Currently, my TDA1541 uses D1Pass as I/U conversion, so I wonder what can be achieved by including the C-3850 between D1Pass and the amplifier? Will this affect the quality and tone of the sound in any way? How then to set the gain of the C-3850? Will this reverse polarity issue have any negative impact?
I would not do that. You can use either the Pass D1 active I/V or passive I/V with the C-3850 as described above. Compare the two, and see which one you like. The quality of the I/V resistor in passive I/V makes a big difference in terms of sound quality. Once you determine the proper value, and if you like the sound quality in general, you can improve it further by using TX2575 metal foil (Vishay Z-foil), (possibly SMD tantalum nitride), or Caddock TF020 thick film resistors.
Reactions: pjasio253
Yes 30 VA are too much.
But
VA is Not Watt
From 15 Volt secondary we get after rectifier 21 volts. This is going to each rail to a voltages Regulator 7815.. etc.
So we have about 2.1 Watt per rail consumption. So overall about 4.2 Watt ....round 5 Watt. So we have bad efficiency of the transformer... can calculated the double. So 10 VA must be fine.
Kr Chris
Reactions: Gulo_Gulo
That orientation is correct. E-352 is the part number, 3.50mA. They should be selected in matched pairs. The data sheet also has a table "How to compensate current reduction due to heat up of the CRD. For currents of 1 mA or more, resistors can be used together with CRDs to compensate for current decreases and fluctuations. The following values are typical for compensation resistors." For the E-352 it lists an 82K resistor. The resistor is placed in parallel with the CRD.
@chalky mods in Post #177 .
Reactions: Berlusconi
I have finally tried this preamp. Needed 15dB gain. It sounds very nice with the original circuit. Just starting from the power supply. The usual recommended output caps in the datasheet for the L7815 is 0.1uF and L7915 is 1uF. These are for optimal transient response. Music requires transient response. The circuit uses 100uF, which seems way too high. Has anyone tried 0.1uF and 1uF in place of the 100uF?
Just an opinion, but I would skip the onboard PSU and 'pipe-in' your own DC supply rails. Using a separate power supply will cost more money and effort, but you can skip those components on the C-3850 PCB. In my view, it does not cost much more, really, but it can be considered trivial or diminishing returns with such a circuit.
Here is a pic with some landmarks on it. Could be handy when using the Chalky Schematic?
Cheers
