New AK4497SVQ Build!
@TNT
schematic is not in a state that can be judged right now.
output stage is not much different from what altor suggested.
We need to think about the Analog Switch IC VS Relay to be used for conversion, (I think relay is better.)
and it has not been decided which of the two functions to add (XLR or HP AMP).
I will post the full schematic once the component selection is confirmed.
There is a problem printing pdf. I've moved this project to ORCAD X and I'm not yet familiar with it.
Reactions: TNT and MarcelvdG
Not understanding the question and drawing 100% but I take you mean if metallized through PCB mounting holes should be connected to xGND? Will it be a class I or a class II device? Normally DIY and a metal casing means class I. Either choice has implications for the grounding scheme. Normally one leaves connectors floating from the casing and arranges grounding scheme on the PCB.
Can’t help with metal casing and class II. Sorry. Make sure you will have a way to direct leakage current to. No PE pin on PSU is awkward in cases when plugging stuff in and out. Just think of consequences of hot plugging hot pluggable HDMI 🙂 Also not the best scheme for mains filtering.
Reactions: Mins
The project was delayed due to personal reasons.
power supply Schema.
Added EMI filter module and diodes for prevent board destruction. Are there enough devices for safety?
(Reference error: RTC1->PTC1)
PCBs are now being designed by experts.
@altor
Dear alex, I'd like to know a little more about the output stage. I bought Douglas' book to better understand small signal control,
and found some material on resistor noise and distortion.
What parts did you use? According to the a10s board pictures you posted,
some of the resistors look like they were specifically selected for different parts. (no values shown)
ps
I have some difficulty using high quality resistors for 1k33 or 1k78. Would it be okay to standardize all of them to 1k5 except 250R and 510R? (G=1)
RG or MMx MELF are always good choices.
Regarding Susumu RG, in my personal subjective opinion they are not always good for audio. In a 32-bit FIRDAC using RG resistors in the output array produced very weird sound, especially at bass frequencies. Really blurred bass. My best guess is that the resulting sound was of 1/f current noise intermodulated with the audio signal. Yageo RT sounded much better, and was one of the best. SMD metal foil sounded the most clear by a slim margin over the Yageo. It seems like metal film resistors like other things involve engineering tradeoffs. Lowest current noise may not the most important spec for RG, especially since Susumu has a line of low noise resistors aimed specifically at audio applications. However, those audio resistors aren't claimed to be especially optimized other than for low current noise.
Thanks. I also read the thread about FIR DACs and remember the content.
I agree. The public information is too sparse to specify a special purpose.
Foil resistors would be nice, but they are too expensive.
Someday I'd like to build a DAC using Texas Components foil resistors.
The build delay is entirely due to the PCB layout.
I chose someone with enough experience and was confident he would do a better job than me.
However, the layout was not optimized for performance and the placement of all components,
including R and C for symmetrical circuits, is not symmetrical or has mismatched spacing. I am spending almost 3 weeks to direct everything.
I've seen countless PCBs and I've never seen one with such a disorganized component layout.
It's as if it was blown in by the wind and stuck...
with the grid feature I don't think it's going to be disorganized at all.
