Pluvia 7HD cabinet recommendations
Hi all,
I built a pair of DIY open baffle speakers using a Pluvia 7HD full range driver together with 2 Peerless 12 inch drivers for lf. I would like to keep things as simple as possible, and I don't like the need for a seperate DSP and two power amplifiers.
So I was wondering, if there exists a well performing single driver Pluvia 7HD design? I'm aware of some free plans on the Mark Audio website. But how about lf-range for such a small driver? I don't need very low lf range, but I guess it should at least reach about 60-80 Hz (-3dB) to have some acceptable lf? Any suggestions about which design would be suitable? Or should I get a bigger driver?
Reactions: sdsddsd1
Yep, I loved my microTowers for many years, first with EL70 then much more with P7.2HD. No bass support needed.
Sadly, I had to remove the drivers and throw the boxes in a dumpster about six months ago when my wife and I relocated to Japan. I did bring the two pair of drivers with me, and now I am partway through a Maeshowe build for 2 of Pluvias and really excited to hear my first BLH. I have no doubt the bass will be satisfying.
I might build Cornu spiral horns with the other pair and use them in the kitchen or dining room.
Lots of great options!!!
Reactions: zman01 and von Ah
Would deeply appreciate a succinct summary of the microTower auditory effect or a pointer to specific information -- the massive thread here is unfortunately too long to wade through.
(Half-seriously) I think there might be a weird mental interferometry that turned widely-spaced timing/phase differences into perceived extra detail. Really?
My stacked micor55 became "FR-perfect" LX after I had unintensionally/unsuspectingly heard them firing up+front but not even contiguous. Hence the previous paragraph.
@wchang The easiest way for me to characterize the microTowers (in the “Castle” configuration) is to say they bring the band into the room. Some speakers can transport you into the studio with the musicians, with pinpoint precision, imaging and soundstage (as long as you get your head right in the sweet spot). The microTowers put the band in your room, for better or worse, and sound good from pretty much anywhere in the room - better yet in their generous sweet spot. I may build another pair some day, but it’s time for me to explore other options. Been lusting after Silbury for about a decade, but I’ve got P7HD waiting in boxes so Maeshowe will have to scratch the itch for now.
Reactions: wchang
Hi, thanks again for your responses! The Frugel Horn MK3 looks interesting. If I'm correct, it's a combination of a transissionline and horn. Is there any explanation online about how this exactly works? And if I'm correct, my Pluvia 7HD speakers are compatible with this design?
Exactly. If you require some extra SPLs, or have a large room, then build something bigger that will move some air. Otherwise, bandwidth isn't an issue.
jeff
I would like to use the speaker in a 6x10 meters room, which is large. I would like to make a small corner where I put my audio setup - the rest of the room is my woodworking workshop. I usually listen on moderate spl levels - I don't like loud. Would these Frugel Horn MK3 still be ok for such a room? I won't sit too far away from the speakers.
