5v SMPS supply with proposed mod for music streamer
5v smps supply 2Amps with a proposed mod and emi filter. Is this good.? Will supply the Wiim music streamer appreciate comments. Thanks
The experiments I did with a Meanwell IRM-20-5 module coupled to an AmyAlice were positive. I prefer a linear PSU for sensitive stuff but the aforementioned combination sure is OK and way better than just the SMPS module.
Wiim makes a few devices. It would help to mention which one or its power consumption.
Reactions: ronnieponsones
Jean-Paul, are you talking about this type of coils? Any further comment? In your honest opinion, is it difficult to see sound quality improvement for linear power supply used in front end digital source ( dac, standalone streamer)??
Hi no the coils as used in AmyAlice. Not the holy grail but a well designed and tested filter for low power SMPS. I would pick stuff that is tested and proven. A good design is a combination of factors with the usual drawbacks mitigated.
If you want gerbers to have PCBs made for a Meanwell IRM-20-5 and that filter on 1 PCB you can have mine. Combine with an IEC inlet with built in filter and fuse and you will have a pretty good setup.
Oh I can change the design to USB-C if you can deliver the right pinout and type. I don’t see any benefit in it though. There are way better connectors.
Quick/convenient are often the enemies of good. Since I stock Lemo I use those quite often.
Seller gfu-nuernberg on ebay.de sells the Meanwell IRM-20-5 for 3.99 Euro. I bought a lot and they are the real deal made in 2021. Can be combined with the IRM-20-12 but only after a friendly e-mail (to avoid double shipping costs). Power in abundance, how nice is that.
I know surely there are way better power connectors about there but most devices these days use USB Type-C, so we just need a stock C-C cable and get it work. Different connectors on each side is quite an inconvinience.
If it uses only power and gnd, and no need for a handshake or any RD, fairly easy to modify my version of amyalice. Also pads for additional DC barrel output. 55x65mm, very small, can fit any cheap aliexpress case.
View attachment 1398672View attachment 1398675
That looks awesome! The USB-C port is strictly for powering so I don't think there is any other pins involved. What smps module did you use? I just remembered Mean-Well doesn't have any small 5v smps, not sure if I missed anything else.
Good reliable IRM-20-5. 4A 5V (with filter up to 3A only).
Easy then, 6p type c connector and you're good to go. I'll post gerbers and link here.
Reactions: thuanth43
OK then I won’t. Two of the same is not needed.
Most also are mediocre for audio. Replacing both chassis part and connector is in the same quality thinking. It is the total sum not just 1 detail.
BTW they can’t be different as they need to mate. With an upgrade PSU they also only need to be detachable at the device skipping one weak part/error possibility in the chain.
