The M2 Output Stage in Class A/B, and maybe a Power WHAMMY?
last one....realistic 3_ with 31V rail and standard BJT transistors simulated! (not build and tested)
setup is 13,8dB gain, 5,6Vpeak input needed.
maximum swing is 27,414V peak...not bad for a opamp LT 1793 with +/- 15Vrail
kr
chris
hi admin
how is it possible that my LTspice file is changed?
post 458
...with R1, R2 11k it is working
now it is changed to 33k...it is not working.
kr
chris
this could be a solution for placement 3x TO-220 for new pcb design
shift Cs1,2 up and make place for traces etc.
