F5 power amplifier
I want to make sure my poor understanding.
Just a bit of confusion that's all. Too many amps are called F5 hehehe, I'm getting advice from several camps.
Sure, the idea being to spread the force more evenly across the transistor and not put too much stress on one point...mission accomplished.
I was looking back at Jim's build guide and came across the photo posted below:
Your standoffs are quite a bit taller than his and I'm hoping the leads on the thermistors you ordered are long enough to bend up over those transistor legs and down to the transistor body. Also, Isn't it standard practice now to have the thermistor touch the plastic casing rather than the washer? Obviously it worked for Jim but I was told not to do it that way. I guess the reasoning would be if the coating on the thermistor were chipped it would make electrical contact with the washer.
Reactions: windwardmt
From the original article:
Th1 and Th2 are small 4.7 Kohm thermistors that have been placed in series with R15 and R16 respectively. The resistance of the thermistor declines with temperature, and if placed in close proximity to the output transistors will help compensate for thermal drift. You can build the amplifier without them, but you will have a longer warm-up time and you will spend more time adjusting the bias.
Reactions: DrDyna
I gathered items.
I saw EUVL's degeneration jfet matching. 2sk170/2sj74 7.0mA/7.8mA
Matched 2sk1530/2sj201
0.22ohm source resistors and 50ohm feedback resistors.
I would like to have check the schematic and value.
I built the original gb f5 around 2011 or so and I’ve been running it with an aikido 24v preamp. Due to a move I’m reconsidering my listening room layout which would result in my preamp and sources being pit in a rack on the side wall rather than between the speakers.
Interconnect length between pre and f5 would be 4 meters or so, hence considering going for xlr. What would it take to modify my f5?
