Kenwood KAC-PS401m stuck in protection
Hi I have a KAC PS401m on the bench stuck in protection mode flashing also low battery led on.
The crossover board had the usual corrosion from sticky fibre tape, I've removed the tape, cleaned up the corroded traces and pads, re run the solder and tested the traces for continuity also replaced the capacitors on the board and its made no difference, the relays don't click on and the aforementioned remained flashing/on.
Any ideas on what to check next would be appreciated.
