DIY Front End 2022
I started with +12dB (which is R3 & R4 = 40kohm) on my MoFo. I like to socket things until I settle on a permanent value,
When I'm happy with the value, I remove the socket then solder in permanently.
BTW, these are my own PCBs with Texas Instruments JFE2140 as the long tailed pair. Can also use LSK389 SOIC or TO-71.
I got a little impatient waiting for boards to be stocked in The Store. :sly:
Thank you very much @Ben Mah and @jt23.
I've rewired as described and noticed I forgot to short R13. Here is an updated wiring plan.
Proof of concept works! I built and added R0 boards to my TDV. Stock FE2022 with kit transistors. 10x gain. Power supply is a mere +28VDC. Sounds quite nice.
Now I gotta figure out how to securely attach them to the chassis. :smash:
After this success, I’m going to get fancy with the R1 kit I have. That one will get either a bunch of K170s, a double bunch of K209s on adapter PCBs, or some K369s I have stashed away. :Popworm: Those boards will go in my BOO OS build.
Thanks again, Nelson!
