DAC AD1862: Almost THT, I2S input, NOS, R-2R
That's the exact one and seller that I've just bought. It's been dispatched also.
Was reading up on removing L1 (0 ohm resistor actually) and I shall use a separate cleaner 5v PSU.
Yep, use linear supply for it. At first glance they appear to have done a better job for external supply with 2 pins free by the connector, but not one has gnd connection. So you still have to scrape solder mask a bit on the bottom to connect gnd.
