Question about tape equalization preamp
“And, although C75 and C21 are now in parallel, depending on the PCB layout, it may be a good idea to leave C75 in place, especially if it's close to the opamp and C21 not so close”
— I guess C75 being 0.5‰ of C21, it has no meaningful impact on the transition frequency.
I am adding the PCB layout for reference (before my current changes).
No, but it may have an impact on stability, which is what it's there for originally. Such caps are placed close to the opamp to prevent trace inductance from interfering with their purpose. That's why even if it looks like it's doing nothing being in parallel with a much larger capacitance, I'd leave it be.
the curve is going up or down after the pole or flattening to a zero.
That is exactly the case. Poles go up or down, zeros go flat (or at least flatter), with increasing frequency.
Is that just shorthand for people who really understand electronics or should it in fact be indicated in same manner?
The terminology derives from the mathematics concerned.
I would like to thank everyone, these mods worked out perfectly. I have since also increased the gain by cutting resistors R62/79 in half (red rectangles) but I need to go a bit lower yet, as I can use another 6dB of gain. Again, many thanks!
Hi, I have another question on a different but related matter, if I may.
I just fixed this rather rare — and totally obsolete — Grundig “DC International-type cassette” player for cars, from 1966. It is meant to work with a matching radio — when a cassette is played, the radio audio is interrupted and instead the tape preamp output is sent to the power amp in the radio.
My question — primarily because I am ignorant of these earlier transistor designs — is why they have used an output transformer? The transformer measures as 1:1, so I assumed it is not for voltage gain. It is also not, presumably, driving a low impedance load?
If I wanted to bypass that transformer, can I just attach a capacitor to one leg of the input side? Should / could I also disconnect the transformer and replace it with a like value (315Ω) resistor.
The output signal is on the low side but perfectly acceptable. In my trials I connected the transformer output directly to a “today’s” power amp, skipping the original cable and the potentiometer.
I would appreciate any feedback and all the best,
Ali Elam
Galvanic separation, the output is floating. The unit can work either with + or - on the cars ground (switch KS2).
Thank you! So it has nothing to do with impedance matching or amplification but for floating the output with respect to ground, B+ and so forth. Can I not eliminate it if I stick to simply (-) ground?
Whoever owned or installed this before, took out the voltage conversion bar (KS1, not needed for 12V) and broke the outside tip of the polarity changer, KS2, so it cannot be accessed without removing the enclosure.
Thank you again.
Thank you, I will.
This is a nicely made, high quality machine. Once I figured out voltage and polarity, it worked immediately. Even the motor belt was in good shape.
(Of course from a practical point of view it is completely useless, being stillborn even in its day. But if we do not preserve gadgets of the past [even the mistakes], who will?)
So far I only added a drop of synthetic clock oil.
The real question (!) for me is...do I mount a stereo head...change the amplifier...record tapes on a cassette player after first adjusting for the 5.08/4.75cm speed difference on Audacity...swap the tape from the CC to the DC..!
I have seven DC cassettes. Not many on offer. Maybe I can 3D print some!
Can you please post some photographs with details of the aunit. Especially the head and the pinch roller.
I have a Grundig C200 SL Automatic in mint condition (NOS, NIB) and would like to see if there are any similarities.
Thank you.
