how to convert this amplifier to an 15/18V supply?
my attemps werent succesfull and i also dont own an big enough heatsink and an transformer to complete it as is, by attempts i meant copy-ing the circuit into ltspice and changing the values, i also didnt have enough time.
and here it is an fully scaled down nelson pass zen amplifier, vr1 adjusts the output voltage to be at half of the supply, i heard you could add an extra poly or mkt cap or connect two output capacitors in parallel with eacch other and so on, an source resistor to decrease distortion and it seems to be quite good at it.
Have you measured if you have half of the supply voltage before the speaker cap ? C1.
Also the current on M2. ?.
Reactions: rayma
