Problem with input selector
Hi guys,
I have a problem with preamp Rеgа Сursа 3. The input selector does not function. Management is carried out by pic16c62b -> motor driver -> mechanical switch. Back in the day there was a service bulletin from Rega for additional grounding of this controller to the chassis, but my web search was unsuccessful.
However, from what I've read about such controllers, I understand that the chip inputs that are not in use should probably be grounded.
I welcome any advice.
datasheet
Regards!
Hi. It's bad idea to ground unused processors pins. Pic controller has one difference from just logic ic - logic ic may have unused inputs, whose better not to be left floating. But processor's unused pins will have no action if their function is not defined in code while programming. Also same pin can be used as input or output, function defined when writing code. Another case is when same cpu is used in different models of similar devices, and some pins are left unconnected in some model's, but firmware is the same. What will happen if you ground unused pin, thinking that it's input, but in code it's definition is output? Cpu will be damaged, if for any reason will try to output logic "1". So if you are not 100 percent sure which pins can be safely grounded, use resistor 10k in series to gnd.
But in your case if input selector is not working, there are several possible causes. Cpu itself is bad, firmware become corrupt, and you need to reflash it, or clone from similar cpu, if that's possible, or conditions to work not meet, or cpu surrounding parts are bad, like voltage supervisor ic. Maybe processor is thinking unit is in standby, or that supply voltage is too low, or some other, defined in code. Sometimes it's clear by looking at schematic. If schematic not available, you have to draw it by yourself, or use another processor and make your own module , to work same way and perform same function.
Sometimes firmware in old units can become bad. EPROM memory is not same as oldest memory chips, where a jumpers were burned by programming. Eeprom stores charge and that charge decreases with time, however not few years are needed for corruption. On this forum there are several posts about corrupt firmware on old cd players as example.
Sometime you can just reload the firmware and the PIC/ATmega/ESP32 will run good again.
I play with all 3 (LED's and protection circuits).
I had an old Nvidia card act "squirrely" , reflashed the video bios with a added verbose command (shows on boot)
even changed the fan speed. Worked perfect afterwards (old GT560).
OS
Most I/O have internal pullup resisters than can be specified in software.
So you could terminate a pin in code.
Of course , that's not as reliable as a real pullup resister , 10K is the most common.
OS
Hi guys,
The only free pins are 25 and 26 which have 4.95V. I connected them to ground with 10k resistors, but there was no improvement.
There is 5V on MCLR pin1, clock is Ok.
i don't have the firmware and i have no way to flash it even if i had it.
Is there anything else I can do?
I found that pin 11 and 12 control the volume motor driver. This worked fine - increas and decreas.
Pins 13 and 14 control the input selector motor driver. On an oscilloscope I see that pin 14 has constant ~ 5V which is the problem.
Where is going pin 14? To driver ic or transistors maybe ? Can you somehow disconnect this pin or track, maybe desolder resistor or transistor ,jumper, whatever, to check where those 5v appears on - from processor itself, or from motor driver?
