FM Acoustics 711 schematic
I don’t want to offend anyone. But how can you assemble radio equipment without understanding the circuits, even a basic power supply? Isn’t it easier to find someone who is good with a soldering iron and assemble a construction set with him? After such manufacturing, replicas begin, like all the Chinese crap doesn’t work. On the Dartzeel forum there were a lot of dissatisfied people from those who bought bad components in the hope that they would sing for $20,000. Normal guys assemble and are happy. FM Acoustics are from the same series. There are different boards, if you save, the result is the same. No offense to anyone that hurt)):wave2:
Did I say that the fm711 amplifier that I assembled does not work or sounds bad, it sounds great, but in the description they write and post a connection diagram that has nothing to do with my transformer that is connected to my amplifier, that’s why I write that I would draw how connect my transformer with zero to the amplifier, because... There is no zero in the diagram that was thrown off.
And it’s not clear how the green board differs from the yellow one; from the photo I see that it’s only the resistors and probably the color
  • FM-19510-CMRR-Test-input.pdf
  • FM-1.5K.pdf
    FM-1.5K.pdf
  • fm-155-3K.asc
    fm-155-3K.asc
  • fm-155-mk2.asc
    fm-155-mk2.asc
https://www.accuphase.com/historys/c-265_e1.htm
Balanced Output Stage With Bridged Feedback
In balanced signal transmission, two identical signals are transmitted simultaneously with inverted phase and combined at the receiving end, thereby canceling out common-mode noise and interference. This assures pure high-quality signal transmission. The principle of balanced sound transmission is shown in Figure 4. The outputs of the two amplifiers AMP1 and AMP2 are connected to form a cross-feedback loop, which sends the symmetrical (+) and (-) signals with low impedance to the next stage. The signals are isolated from the ground line, resulting in an ideal balanced circuit. Even if one side of the output is grounded, both amplifiers continue to operate, and the output voltage does not change.
https://gw.alicdn.com/bao/uploaded/i1/O1CN01nS3SXf1O6Udxz36FL_!!2-fleamarket.png_.webp
