The food thread
I'm very happy with this chef's knife from KAI. It cuts beautifully and retains a great edge for weeks; then I re-sharpen it to 15 degrees bevel using my Chefs Choice 15XV electric sharpener. Unlike most Wusthof and Henckles chef's knives, you can sharpen the entire length of this blade including the last 2 cm; the heel (circled in orange) is the same width as the rest of the blade. Five stars, would buy again.
_
Reactions: MITsound
Gee, I feel left out.
My sharpening bench has four different wheels with guides, a specific holder for drill bits, a 12” rotating wet flat stone, three belt grinders of assorted sizes, a felt flap wheel with rouge and a leather wheel. Of course a granite flat stone to use with up to 4,000 grit paper.
I just rebuilt a WWII Brown & Sharpe 2B surface grinder for larger bits that need to be sharpened.
I only have four of the modern diamond stones, but make up for it with half a dozen or so real ones, including an Arkansas one and a very old carborundum one originally used for stropping razors.
It did take me a few years to get decent sharpening knives by hand. I did get a tool to hold chisels and it failed by flattening its’ wheel.
Of course the tool I use most on my kitchen knives is a “Steel.”
As to hollow grinding, I use that mostly for flat blade screwdrivers.
One of my guys offered to sharpen my Swiss army pen knife. It came back with half the blade ground down.
Honing I do every knife use. However I am grinding something at least once a week.
There is one tool I cannot sharpen! (A Phillips screwdriver.)
Reactions: TheGimp and tobydog
The only time I would spend money on someone else doing an edge is if I wanted a hollow ground.
Other than that I still wonder why anyone wastes valuable cooking time sharpening manually. Every year a new and improved one comes out and I just smile. I was there once and have not forgiven myself for waiting 20 years to buy a proper sharpener.
As far as grinding goes, I use a grinder for coffee and a blade spinner for spices. The two shall never meet.
I guess because my sharpener was worn out, and I hadn't found one locally that day, and didn't want to wait for the three day delivery time for another back then.
Case solved.
Not left out Ed. Like the rest of us we have to add our piece every once in a while.
We already know you win, you have each time you mention your set up, but you are mostly talking industrial, while we're talking about something you can store on your kitchen counter, and costs a few hundred bucks. You're bringing a monster truck to a go-kart rally.
OK then....
One of my pastimes at work last decade was setting up 4 cells for sharpening $%&"s, a trade secret. I reckon my little Fanucs could be taught to do an excellent job. 5 - 10 seconds.
I just use a broken piece of an old scythe sharpening stone in the kitchen for knife sharpening, it ain't rocket surgery.😎
One of my little Fanucs😉
The turmeric in solid form is hard, and the impact of it on the blade is more than most other spices or food ingredients.
The drive from motor to blade, and the mechanism itself have to be strong enough to bear this.
As per my sister, who lives in Dubai, the ladies there have a preference for Indian makes, the models by Braun (for example), and others, have been known to break the blades while grinding turmeric.
So it is a sort of test if the machine is strong, or not quite good enough.
No ties to any make mentioned above.
Slow speed grinding, in a hand mill, will not raise the temperature or oxidize the dry ingredients as much as a motor driven unit, and personally I prefer coarse ground spices, the flavor retention in storage is better than with fine ground spices.
Reactions: Black Stuart
Commercial ground pepper is awful. I buy a kilo of whole black pepper and use a mortar and pestle to pound it into rough pieces, gives a much better flavour to every dish. Just enough to last a few days. The only time I use white pepper (which is the inner core of a whole black peppercorn) is when making an authentic Gazpacho.
Hey Mark,
That did make for some good reading and it looks like a good product as well. Sounds like something that will sell. For me, until it breaks or wears out, I will stick with my 40 year old hand crank unit. It has almost infinite coarseness settings, is easy on the wrist and has a decent reservoir. I expect it would outlive and out grind that cannon as well. It wasn't very expensive IIRC. I didn't have a lot of money 40 years ago. I think I bought it for someone who gave it back saying they hadn't used it in a year so...
... and if you look at the second picture, the shiny spots on the lower casting are wear marks. IOW it has seen the love since coming home.
