Measurement mics
the yellow one is 2022 and the green one is 2009
Thanks! So it actually drifted to more linear 😀. My experience with an ECM8000 is pretty alike. In 10 years time not that much drift. But still. Earthworks recommends calibration each 5 years. With professional grade sound lab stuff annually is some kind of upper limit.
Now our requirements aren’t that high most of the time. Level deviations of some tenths to half of a dB are acceptable. The noise figures often are determined by diaphragm size. Leaving distortion figures and the drift in those as the big unknown. Has anyone ever inquired for a pro grade full calibration service that includes distortion figures? You can buy a nice new classy measurement microphone for that kind of money.
So let’s not fool ourselves. Unless properly calibrated, we have to administer for uncertainties in our acoustic measurements with older mikes. Which likely are in the order of magnitude applying to the difference between ‘cheap’ mike - ‘reasonable’ mike. Luckily at least some parties offer limited calibration services for budget prices.
Reactions: aslepekis
You are probably asking a rhetorical question. But I'll bite.
I recently (2024) enquired about a calibration here in Australia-
I was offered an Accredited Calibration
"Accredited calibrations are performed in service centers accredited by the local accreditation bodies according to EN ISO/IEC 17025 standards. This proves the traceability back to the International System of Units (SI).
A calibration includes the following measurements:
  • Visual inspection
  • Sensitivity measurements
  • Frequency response
The calibration certificate specifies the measurement uncertainty."
I'm not sure if there are (m)any other labs in Australia that can offer accredited calibration that's traceable back to SI units
The cost was AUD $1400, ex taxes. (2 significant figures). For those not familiar with AUD, at the time of the enquiry, the exchange rate for Australian micro pesos is US$ 950, €880 or £750.
Some organizations/companies may require this for policy/legal requirements, and thus turn this into a taxable business expense. But it was enough to stop me from enquiring about extended testing (like distortion measurements)
There's probably a small business opportunity for someone like @IamJF who can provide distortion measurements for microphones.
Unfortunately he's too busy in his day job, designing/building speakers and microphones pre-amps for the microphones companies...
If there's a single one line summary I could give is, if you want a microphone that has lower self-distortion eg. <0.01% THD (< -80dB, H2 bound), look for one that can handle HIGHER SPL at given %THD. eg. 160dB @3% THD; 145dB @1 THD.
It may be a little while before low cost microphones with low distortion arrive...(see below article)
Reactions: IamJF
If inspecting a mic for damage, providing electronic conpensation file, and sensitivity figures on a certificate that is traceable back to SI standards costs only €880
How much would additional distortion analysis cost?
? €1000
Why bother, as you say.
Time to buy a new mic
We used a LOT of B&K 4133 microphones when we made speakers in the UK. They were calibrated annually. Actually B&K, Manchester, calibrated one mike for us each year and we used that to calibrate the others. But each mike's calibration could be traced back to the B&K UK NPL standard
In some 2 decades, NONE of them were more than 0.2dB out except when there was obvious damage.
For electrets (eg the Behringer, ECM8000), I have some experience this Century. It depends on the environment where they are used & stored.
Over, a 10 yr period, a mike stored in an air-conditioned studio, in Oxford, UK has no detectable (<0.2dB) change. In the same period, a mike (mine) in Cooktown, Oz had unacceptable changes in both sensitivity and response (1dB). These are the limits of quite a few which have passed through my hands this Millenium. Most were not quite as bad as the Cooktown sample or as good as the Oxford one.
A 'modern' electret 'measurement' mike for DIY work or recording which doesn't need traceable calibration for legal reasons, is probably OK if re-calibrated every 2 yrs. I include the Earthworks in this call.
Consistent with B&K material:
"Artificial Ageing During production, the microphone cartridges are subjected to a high temperature (150°C), forced ageing process which ensures excellent long-term stability. The predicted long-term stability is of the order of 1 dB over several hundred years at room temperature. Although difficult to verify this in practice, the sensitivities of several microphone cartridges measured periodically at Brüel & Kjær’s laboratory from 1974 to 1990 changed by only 0.05 dB, confirming the predicted long term stability"
Reactions: IamJF
I see a long term drift test of cheap and middle priced microphones coming up…
But from a practical pov you can buy the one you like best and either send it for a check every few years or buy a cheap corrected one and compare yourself every couple of years. The latter option then again fills your closet unless you resell them. All viable and giving us instruments within the tolerances we need.
Reactions: chirs and aslepekis
I just purchased the cheap Dayton iMM-6 mic, downloaded the calibration file and the Room EQ Wizard soft and measured my Dynaudio Emit speakers at their normal computer tabletop location from my normal sitting position.
The yellow line looks sufficiently crappy, the green line I don't even know what it is. Do you think the measurement is correct enough? How would you interpret it?
My two dayton mics show a difference when measuring the same thing:
I did not expect them to match but I wish they did.
So I thought I'd compare the calibration files of a few mics. Huge props to Audix support for sending me some random cal files. Comparing the audix cal (blue shades), my 2 dayton mics(red shades), and an a m23r earthworks I found online (green)
The cal for the earthworks looks less extreme. The dayton look the worst. The audix in the middle.
This post on another site went through a few earthworks mics:
https://www.audiosciencereview.com/...-deviation-of-6-earthworks-microphones.40546/
I am waiting to see if earthworks will send me some calibration files before making a choice.
