What will you do with your Peerless by Tympahny DFM-2535R00-08?
Thanks to @Mitch311 for suggesting this thread.
Huge thanks to @sheeple for organising the group buy
So, what will you do with your drivers from the group buy?
I intend to try them in my DIY SH50 style MEH horns.
Seen here with BMS4550s
They have to reach down to the 5" mids.
They will be used in a hifi setting and not huge volumes, hopefully they will take it..
I have a pair of BMS 4550 drivers for PA🙂
I'm using my Vitavox S2s at the moment, and have made an easy screw in adapter for fast swap over.
Here with the S2 and full driver compliment
I'm sure more then just me would love to see your builds and uses.
What's planned and what's on the work bench?
I have a pair of the drivers from back when they were on sale to the general public. Going to use them in an upcoming build. Very interested to see what you folks come up with as far as horns/waveguides and useable frequency response.
Dan
Curious where you heard that? But the larger back chamber is an interesting proposition.
I am also contemplating a possible MEH build with a likely 1200Hz target, but not yet designed.
Sorry i somehow got that wrong. Most seem to use it down to 1.5k with higher order. So i think 1.2k and first order could be possible with a bigger rear cover.
Is it possible to get a 3D drawing from the manufacturer? That way it should be straight forward to design a rear cover.
Reactions: Wright
Yeah, not sure about a true 3D drawing but we do have a few resources just from the Group Buy thread that should be helpful for anyone who might be interested in taking that on. I haven't learned any 3d printing software yet but maybe a project for this winter...
Reactions: Speedysteve7
Ultimately low frequency extension vs. max SPL is limited by excursion of the dome, before it hits the phase plug. I think one can do overexcursion with compression drivers without problems, before burning the voice coil. So, same effect, low frequency boost, can be done with EQ as well, at least to try it out whether it is something important or not, to test what are the limits for the driver. If one wishes to get rid of the EQ then try manipulate the enclosure.
I'd think it's same as with woofers, enlarge the box to get driver resonance down a bit, but also Q changes. Damping would help kill harmonics within the cavity, but also dampen the resonance reducing the low frequency output, reducing Q. What ever you do make sure the high frequency performance does not suffer as trade-off. Low frequency extension (to make full range system) is done by crossing over to larger driver at some frequency, so it's counter productive to ruin top trying to extend the low for any single driver, as there is nothing one can do to fix the performance other than revert the changes. Or use another driver that can do it if it is must to extend the low end of the tweeter.
The DFM driver seems to have very good performance eyeballing frequency response charts posted online, better than 99% of other drivers making it top shelf performance. I'm bit skeptical modifications would make it any better, odds are the performance goes down rather. Although there might be some playroom because the driver is for high SPL use and home use could be low SPL. No one bends physics, even the audiophile are bound to it 🙂 have fun with your projects!
