Choctaw - 10 Watt Amplifier, 1 Opamp + 2 MOSFET
Our colleague LineUp has too many ideas - one amplifier per week🤣
Feel free to use
I have no more space for prototypes😆
I am looking for a beta tester specifically for MADE BY LINEUP projects
I am attaching gerbers
  • untitled.zip
    untitled.zip
Reactions: U102324
I am going to be pedantic and say the three connectors would look nice if they where horizontally lined up. Also the power transistors should not be clamped to the heatsink by the PCB else the underside of the connectors will push holes into them. So the power transistor mounting hole should have a diameter bigger than m3 screw head and the power transistor clamped by the screw only. Sorry, I am a bit of a visual perfectionist. I can't stand pictures not lined up on the wall. 😱
Thank you for your comments
The mounting screw hole is 5.5 mm in diameter I use M2.5 screws. It fits perfectly
The connectors are used on the PCB only as a "footprint" I ALWAYS solder the cable directly to the PBC
If you use long enough spacers - nothing will touch (see photo)
But if these details bother you You can always modify the PCB based on the gerbers in KiCAD
Reactions: U102324
I would place the transistors beside the circuit board so that they are freely accessible. Then it also works without holes for their legs. This arrangement is easier to handle at the latest when it comes to comparing parts regarding sound.
Reactions: U102324
Zoltan, what about using surface mount resistors, say 1206 size
I made PCBs for my own needs, taking into account my personal limitations (age, vision problems)
SMD components are something I avoid as much as I can
Considering the prices of making PCBs, for example in JLC PCB, IMO making a single-sided board does not make much sense
If we do not strive to minimize PCBs - then there will be large "audiophile grade" electrolytic capacitors anyway
I would feed the output stage with RAW DC +-25V and stabilize the supply voltage for the OPA with a 7815/7915 or similar.
Powering the OP-AMP with 15V limits the output voltage
So powering the output stage with a higher voltage won't give much more power
I may be wrong but the output stage has a gain of 1 (theoretically) so the output voltage at the amplifier's output will depend only on the signal level at the OP-AMP output
Of course, there is a drop on the output Transistors but I personally don't see much sense in this change
