My MOSFET amplifier designed for music
C+ and C- can be anything that will fit.
5mm-7.5mm pitch. Up to 16mm diameter.
100uF would be the minimum value.
470uF common.
Anything you have on hand that fits the bill would be good.
If you are ordering parts anyway then perhaps something like this: Ultra long life, low impedance, good brand.
https://nz.mouser.com/ProductDetail/Chemi-Con/EKYB630ELL102ML25S?qs=IYueExuAvkqI5AG2KptHhQ==
I went with 1000uF on my build as I had 7.5mm/16mm caps on hand.
C12/C13 will fit a 5mm,7.5mm or 10mm pitch film cap.
https://nz.mouser.com/ProductDetail/WIMA/MKP4-.1-250-10P10?qs=q8ECNkb1/vMlS4csT09B1A==
Would be an optimum film cap.
I didn't populate the 2x 5mm pitch film caps right beside the ground connection. I used one as a convenient place to run a wire to connect the Input ground to the PSU ground on that board. As seen by the blue wire.
I've finally lashed a power supply together. The only transformer I had in my spares box has two secondary windings at 25V/1A so provides an unregulated +/-38Vdc. So for now I'm only going to be able to do the dc measurements. On initial switch-on:
I will also be using a +/-35vdc power supply to test this amp and do I need to consider changing any of the values? I am using the Prasi pcb board with all through hole parts and Exicon ECW10xxx series laterals. My build so far
Looking good so far. With the voltages you mentioned, you should be fine for initial dc/ac measurements prior to fitting the Exicons. As Mooly said in an earlier post, for lower power supply voltages than this, it may be necessary to reduce R27 to provide enough bias current for the 12V zener.
Reactions: manniraj
Following on from a query about the protection board I'm using, I thought it might be useful for anyone else working with Mooly's excellent amp so here is the protection stuff:
Its based on Doug Self's one in his Audio Power Amplifier Design book with MOSFETS in place of the original relay. Works great!
And on a similar topic as my previous post, here is all the data for an output board to match the Mooly Amp and contains the 6mH / 10Ohm elements of the Thiele network.
It's laid out so that it can be mounted either directly onto standard 3/4 inch pitch dual binding posts or stand-alone. It can also be mounted as either left or right hand pitch onto the binding posts (silk screened notation on both sides of the board).
