F5m kit
So it's labelled logically, not where you should solder the wires onto the boards? It's the B rectifier's negative terminal on the negative side of those caps, the A- terminal is grounded/center tapped, and on the schematic, the negative terminal of the single rectifier version goes to the negative side of the capacitors, not center tap.
I might be too stupid for this, but I swear the negative terminal of the single rectifier version seems like it should go to rect B- on the board.
Good evening,
I finished my F5M build and have been listening for a few hours and it sounds outstanding. A huge thank you to Mr Pass and all the helpful members on the forum. I went outside my comfort zone on this build to learn.
