DHT Headphone amp for HifiMan Edition XS
If you can provide 12Vpp (4.24V RMS) on 4P1L power tube grid (Ug), the 100mW output achievable.
See second stage.
p.s.
Small output transformers (Edcor especially) not primary induction champions, so lower -3dB point will be not so low.
Bela could I use 30R for filament bias? Also I need more information for the filaments PSU TIA.
I saw more information for 4p1l operating point THD as power amp Ia-28mA, Ih-600mA, -20V BIAS, 235Va
30R filament bias resistor at 650mA filament current gives -about- 21V bias (unnecessarily large) AND dissipates 14W!!!
At least 50W noninductive resistor required with large passive heatsink!
There is no reason to use it.
For example if you want to use 1:4 SUT driven SE (for example spud) with "normal" 2V RMS input, the "required" bias is practically 11-12V.
2V RMS, 2.828V peek - > 4x "gain" -> practically 10V peek due to the losses, so 15-16R (with 650mA filament current) is "enough". The 15R dissipates 7W, so smaller heatsink required.
And the R.C. requiring only 19-20V DC raw supply.
Sample:
p.s.
If you want to eliminate large dissipations (filament bias resistor, R.C. raw supply larger PSU transformer), use simple cathode bias: 300R//470uF in cathode, R.C. feeds the filament points directly). In this case R.C raw supply needs 7-8V DC only.
Once more: what's the goal?
"Gyrator" loaded, (15R) filament biased 4P1L is good VAS stage, with 1:4 SUT it's capable even almost 160Vpp output swing .... but unable to drive 18R headphone.
If you add another appropriate stage for (this, or another suitable) VAS, which is capable for few hundred mW power at 18R load... this can work ... but you should decide what you want.
The goal is that I use gyrator for 26 load in place of 22K resistor of your schematic, the question is can lower resistance of the filament bias resistor for 4p1l ?
1.) Using gyrator instead of 22k anode load ... it's possible .... but IMO unnecessary. More expensive, and with 20Vpp swing there is no advantage.
2.) With such B++ and estimated anode current, the bias is definite. Not possible using another filament bias resistor value with this filament current.
Sample:
p.s.
I have Lundhal LL1660 configured 1-4,5 could be used?
I'm not sure to use this configuration because the noDac output is a 1-7 step-up, so tx to tx???
But I like the idea because I always believe minus is more.
