Last, but (hopefully) best ever modified and complete NAD 3020
So I recon this should suffice
@analog_sa
well the last one i did certainly improved the sound,IMO anyway, and ive listened to alot of these as ive repaired them over the last couple of years
I certainly appears to make the sound 'cleaner'
I agree some can sound 'wooly', but they all seem a bit different to me everytime i listen to one
certainly not as good as the 3103 IMO, the tone on those is realy good, again IMO.
and its all down to the individuals ear as well i guess
I'll be diplomatic and reserve judgement 🙂 I think I would want to test it first.
You could rig up a transistor on a heatsink and power it from a variable PSU adding a resistor from C to B to turn it on a bit. When you have a voltage and R value that generates some heat try adding a layer of that padding and see if the heat is transferred very quickly to the heatsink.
Reactions: vinylkid58
