Information request for modifying Bose 401s
The upper image in #134 is the original Bose tweeter in the right tower. The lower image in #134 is the new Bose tweeter I just installed into the left tower; the speaker that has been the primary concern because that is the one with the mismatched third-party 8-ohm tweeter.
I just finished replacing the old original Bose tweeter in the right tower with the new Bose tweeter. I have reattached the speakers to my receiver and am listening now.
We are all anxiously awaiting your hopefully final response...
Edit to add:
This is odd. I cut the wires about two inches away from the terminals and found that the grey wire had been spliced with the red and then shrinkwrapped. The black wire also has shrink wrap. Something tells me this is not a factory Bose connection.
Please check the diameter of the tweeter wires that also seems to me larger compared to those that reaches the binding posts on the rear panel of your loudspeakers.
Reactions: 1 user
They sound 100% better! I tested with a couple of indispensable discs.
Thank you to everyone, especially @6thplanet !
Reactions: 1 user
Edit to add:
Those two wires I found connected to the right twoer's original Bose tweeter are somewhat thicker gauge, but only slightly.
It would appear that the problem was down to the fitting of a mismatching, third party tweeter in the left speaker, possibly aggravated by a failing tweeter in the right speaker.
However, it's been a fun ride and hopefully you'll experience no more "muddled highs". May you continue to add F.U.E.L. to your fire! ;)
Reactions: 1 user
Seeing that I can only hear things in the 14khz-32khz range and only above 122db, it shouldn't matter to me.
Okay now you're possibly (and hopefully) kidding me, no problem at all.
However, please note that in some cases what someone like me needs is also a mental "certainty".
Which represents an "anomalous" factor compared to both what it really is expected and/or what is really in so-called reality. :)
One with a hand tool, the other by hand. Really not that difficult guys.
Really nice, thanks for showing it!
But also please read just above.
In this case for me it is the long-term reliability that matters, in my opinion.
Good job, anyway. ;)
Not an issue for reliability. Bose has been doing it that way forever.
And yes, definitely easy of assembly. No other cost of a crimp on connector, no extra connections, no added costs for soldering/soldering process.
I have a pneumatic tool that does it instantly.
