Hello all,
MOAP 10.2 ordered normally a deliery end of the week, with a little cherry on the cake: 1 pair sb20frpc30-8
i want to try different box design 1 box of each design and see what it fit me the best
i don't make a frughelhorn due to placement contraint
any suggestion?
- 1 pensil (is it the right design to make?: https://frugal-phile.com/boxlib/pensils/Pensil103-plan-300114.pdf )
- 1 DDVP 15 https://sites.google.com/view/low-e...y-tqwtml-voigt-pipe-with-damp-duct?authuser=0
- 1 TWTD 13.5 https://sites.google.com/view/low-e...ered-wave-tube-with-damp-duct-twtd?authuser=0
any suggestion?
The Pensil is specifically designed for the A10.x
Nandape's ML-Voigt seem to be reused so i am not sure.
It is a valid design, we did pretty much exactly the same topology in 2019 for the FE108e∑, we also did one for the FF165wk, but went no further (so far).
dave
dave
the pensil design for A10.x are not running for MAOP?
why so few design available for this driver (especially considering the price it cost) ?
Hello all,
any suggestion?
If we use a Damp-Duct for TQWT or BH, the control of the box will be stronger, so it can be used with many different types of drivers.
Sound can also be adjusted by adjusting the amount of sound-absorbing material and the area of the duct.
After actually installing and checking various drivers, there are some drivers that are not compatible with each other, but most drivers with different specifications can be used without any problems.
In addition, I have confirmed the Damp-Duct effect with Frugel-Horn Mk3.
As for Pensil, I don't know.
Seems like I've been unlucky. I decided to buy another pair of MAOP 10, but this time from TLHP.
The communication with the support service was terrible. They claim they do not provide matched pairs. The only option now is to return the item. Does anyone maybe has the "B" halves of these drivers?
The difference is significant in parameters. The question is.. will it be that noticeable when listening to them.
FS 2,48%
QMS 3.91%
B X 1 3.42%
CMS 6.59%
RAT 9.43%
h0 2.70%
VAS 3.04%
QES 3.53%
dBSPL 0.15%
MMS 6.18%
RMT 9.43%
L1kHz 2.32%
RE 0%
QTS 3.60%
SD 0%
RMS 9.71%
MMD 6.59%
L10kHz 1.60%
FS 2,48%
QMS 3.91%
B X 1 3.42%
CMS 6.59%
RAT 9.43%
h0 2.70%
VAS 3.04%
QES 3.53%
dBSPL 0.15%
MMS 6.18%
RMT 9.43%
L1kHz 2.32%
RE 0%
QTS 3.60%
SD 0%
RMS 9.71%
MMD 6.59%
L10kHz 1.60%
Here you have mine pair. Maop10.2.
You have to compair.
I dont see so much difference.
I think your pair is ok. Not perfect.
FS is important.
I dont remember how much it will difference between A and B. Max 0.5 % says Mark Audio site.
Not very much.
Not very much.
I hope so too !my pair will be there tomorrow from TLHP i hope it will not be the same!
FS is important.
Not very much.
Yes, I know that. But the seller has his own information at the end of the description file. 😳
After construction, each driver is individually measured in the anechoic chamber at the Markaudio factory. TS parameters are broadly similar to the Alpair 10.3.
I experienced the same @Dispetcher thing with TLHP...not exactly professional communication and in ignorance of the cause, but still I received a very good pair after several emails with examples and photos.
Mark Fenlon should make a course to his dealer. At this price for a driver of this size it have to be perfect! i will see that tomorow
@Dispetcher in wich enclosure will you put it ?
I have already made Mar-Ken10.2 MAOP Trapezoid. They play fantastic. I would like to use them in Pensil 10.3@Dispetcher in wich enclosure will you put it ?
Mark gave up the day to day running of Mark Audio (the company) years ago, do to health reasons.Mark Fenlon should make a course to his dealer.
jeff
Yes. That's Pensil 10.3
In the manual you can find "Note: 3/ bracing is optional. For bracing ideas please see the bracing sheet in the superPensil12 plans"
the Mar-Ken10.2 MAOP Trapezoid is a private plan?
you will be abble to make first listening before me, let us inform about your first trials
- Full Range
- Alpair MAOP 10.2
