New double positive regulator with custom pcb is alive.
It will be used for DAC, one for digital and one for analog power supply.
This is 4 layer pcb with 2 internal ground planes.
Anyways, the supply is extraordinary thanks to the Salas!
Good day! I wanted to know if capacitor C3 is required? If the legs of the microcircuit already have capacitors?
This is a CCS resistor (3 in series), and I didn't have the vaule I needed. It will be replaced soon with single one.Why one side has three TH resistors underneath and the other does not?
It is hard to see but i have PANASONIC 100nf PPS film capacitors between Q2 base and GND (parallel to C2), one is between Q3 base and GND, and there is a 0402 3.3nf C0G capacitor between two leds and GND.
The LEDs are HLMP-6000.
I got interesting results with this configuration. Somehow highs are more alive.
I don't have any preregulation on my DAC - it is supplied directly with this regulator.
And yes, my DAC has only 100nf PPS decoupling capacitors. There are no big electrolytic caps which could influence the regulator
RequiredGood day! I wanted to know if capacitor C3 is required? If the legs of the microcircuit already have capacitors?
Here's the situation, generally more phase shift before zero gain.It is hard to see but i have PANASONIC 100nf PPS film capacitors between Q2 base and GND (parallel to C2), one is between Q3 base and GND, and there is a 0402 3.3nf C0G capacitor between two leds and GND.
Thank you for the graphs Salas. So generally those extra capacitors shouldn't hurt the regulator in any situation?
Is it OK to decrease C1 value to have less effective voltage across M1 for less heat dissipation?
For example I now have 320mA CCS setting, 12VAC 35VA transformer (outputting 13.8VAC), C1 is 4700uF and M1-Vds = 9V
I planned to make C1 2200uf or even lower.
Stability wise they don't hurt it, it still has -120deg phase at zero gain.Thank you for the graphs Salas. So generally those extra capacitors shouldn't hurt the regulator in any situation?
Decreasing C1 increases ripple voltage. Which is AC. Thus you get less DC. I don't think its wise to exchange little heat benefit with more ripple. Ripple is detrimental.Is it OK to decrease C1 value to have less effective voltage across M1 for less heat dissipation?
Hi Nic. Not sure if I missed it but is there an alternative for the application of the FQPs in the Ubib now that they are getting hard to find?
Obviously assuming we need CC >1A.!
Thank you!Stability wise they don't hurt it, it still has -120deg phase at zero gain.
Thanks! So I will find 10VAC transformer insteadDecreasing C1 increases ripple voltage. Which is AC. Thus you get less DC. I don't think its wise to exchange little heat benefit with more ripple. Ripple is detrimental.
You could alternatively add a few Ω power resistor between bridge and C1 making RC filter and eating some DC voltage. It will dissipate some power itself of course. Not a good looking botch on a finished pcb design also.
Hello . I have a question - how low i can go with voltage ?
I want to power I2S over usb kind off like xmos usb to spdif . I need 4 -5.3 v 400ma for usb side and 4.5 -5.3 for oscillator reclock 100ma. I have a transformer 20Va with 10v ac output. Obviously I would built 2 separate ultra bib . Can I power them from the same transformer ?
They would not be connected at any point on the I2S board .
I recieved with my kit PF5103 with label below 7.5 ma . Do I need one per ultra bib ? Where does it need to be installed as on pcb there is 3 of them ?
Thank you .
Thank you .
I thought about that. I might combine a bit bigger resistor (so it fits the PCB) and a lower voltage transformer. I need to buy new transformers anyway.You could alternatively add a few Ω power resistor between bridge and C1 making RC filter and eating some DC voltage. It will dissipate some power itself of course. Not a good looking botch on a finished pcb design also.
Again, thanks for the help!
Hello . Ok . I found info i needed so I installed J3 and silly me I swaped by mistake M1 with M2 soon as i saw no leds and smoke I immediatly turned power off. Pulled M1 and M2 cause needs to change their location anyway. Checked both and both ok on tester . Quick test with multimeter show no components failed . Is that possible . What could fail most likely ? Thank you . I could cut my hand off that i checked everything 10 times . Oh well.
- Power Supplies
- Salas SSLV1.3 UltraBiB shunt regulator
