Acoustic Elegance Issues
Well it’s back to my very helpful community … I have Acoustic Elegance woofers going in a two way horn project.
I have reached out over and over and over and just can’t get them to respond to any post sale questions.
Very frustrating.
I would say they do amazing work but will likely never buy from them again - if you can’t take 2 minutes to respond to an email (sent 4 or 5 over a TWO WEEK PERIOD now)…
Very simple question:
The gigantic rubber “gasket” with holes all the way around… how is that normally mounted?
It seems very awkward and I don’t understand how it’s supposed to look when mounted. I drilled wood screws right through… but it looks TERRIBLE.
Am I able to remove that, and use normal gasket / subwoofer mounting pieces so it has a better “finished” look?
Please see pics for where I’m at with this
Thanks in advance
I don't understand the fuss. The woofer doesn't come with screws or other attachment hardware, and you chose your own. If they don't fit through the holes in the rubber trim ring, that's on you. For what it's worth, if you flex the visible part of the trim ring away, and put the screw through the basket and tighten it it will not pucker the trim ring.
Take it off if you want and toss it in the bin. Of course, without is just as ugly. A person could make a very thin trim ring fabricated from 3mm hardboard, painted black with neodymium magnets epoxied on the back as a trim ring.
Options are limitless when you are the constructor.
Reactions: Arez
It looks like you're mounting on MDF. I strongly advise against wood screws since the hole will likely strip after you've mounted/unmounted the driver a few times [1]. T-nuts or threaded inserts are far superior.
[1] let's be honest, messing with stuff is part of DIY life
Reactions: el156se
Failure to mount a loudspeaker is not the manufacturer's issue. But it's surprising how many questions are asked/expected of the manufacturer. Manufacturers who have no distribution or retailer have to deal with all kinds of issues which are typical of retail customers.
So they should really up their prices and have good customer service.
I wonder if this thread should be changed to "Mounting a large woofer issues". Some years ago I purchased some 15" subwoofers that came with mounting hardware. Ultralow distortion/inductance/variable winding voice coil. A quick start guide.
But unfortunately a fantastic product wasn't enough to prevent a failed business (TC Sounds). AE should look after their customers. Or invest in some more employees or fix their supply chain to speed up manufacturing time. A few bad Google Reviews can really tarnish a good product.
As far as I remember, John has pretty much been a one man show. Not excusing the lack of e-mail replies, but one guy in Green Bay can only do so much. Machining and building woofers from scratch is a hard gig by yourself. Realizing this could help customers manage their expectations, and I feel like most people who are buying AE subs already know this.
I will not use them going forward, I have had a few cross thread or spin out. Now to be fair, I had good results once, but got a batch that were terrible. In good plywood, likely not an issue. MDF, I'd stick with drywall screws or metal screws.
I could see threaded inserts not being worth their while. But tee nuts spinning? Maybe a dab of epoxy or a secondary lock screw from the inside, then?
I feel your pain (meaning I have had a similar experience). Have not owned one of the larger AE drivers but it seems common for manufacturers seem to add these thick rubber trim rings around the mounting flange. I don't exactly know why they do it but it makes the driver are real PITA to mount securely and many fasteners pull into the rubber. I once tried adding some washers but that just looked horrible. Now I pull the rubber rings off and just mount the driver via the cast frame. IMHO this is a much better way to mount a large subwoofer type driver. The rubber trim ring can be un-installed and re-installed later if you wish. I just put them back in the box in case I need it later or if I want to sell the driver and the new owner wants them.
re-opening this after seeing measurements from isolating drivers by not actually screwing them into the front baffle but rather just trapping them between layers of soft rubber. Could this be what AE is intending here- that the end user should build a mechanically strong trim ring, recess the driver in the baffle and then use the trim ring to trap the driver in place and compress the gasket without putting any direct pressure on the driver's metal with an screw heads? This would be an effort to decouple the driver from the baffle. I gather the gasket has a "C" shaped cross section so that it covers both the front and back of the edge of the driver frame?
I can almost guarantee this is NOT what AE is thinking. It's just a rubber gasket, they have been around forever; why over think it? They of course are your drivers so if you want to contemplate woofer mounting schemes for months, well have at it I guess....
