DAC AD1862: Almost THT, I2S input, NOS, R-2R
I have both Miro's AD1862 and AD1860 DAC boards and I realize this is a silly idea to most people but I am thinking that I would like to have them in the same chassis, with one Miro PSU and one Bluetooth source module and use a switch plus non latching relays to alternate between the two DACs.
I happen to have an on-on 6PDT switch that would toggle the power from the PSU between the DACs but I would use non latching relays (probably two 4formCs) to switch the inputs and outputs. Will it be ok to power those relays from the Miro PSU that powers the DACs? And is there any other reason why this is a problematic idea? I know its a, "Why bother?" to pretty much everyone, however unless there is something I am overlooking which constitutes a problem for stability, sound quality etc., I plan to give it a go.
Reactions: miro1360
Relay draws small current, about 20mA, so you can use it 😊
You don't have to worry about any signal problems, it will work.
  • Thank You
Reactions: Minarai
Followup to post 8030.
Attached are Gerbers & a build guide doc including BOM for a power supply PCB for your I2S/USB boards (5V@400mA + 5V@100mA)
This has 2 independent regulated 5V rails with CLC pre-filtering, snubbers, and TH || cap ground breakers. Feed it from 2 pairs of transformer secondaries.
Get some made at your favorite board fab (JLCPCB or similar) and share the extras with your fellow builders.
Thanks to Miro1360 for the fine DAC work, and to Kokanee and Vunce for the inspiration and input on this board.
  • FlexReg i2s PSU-1.0c.zip
  • FlexReg Regulated 2x5V I2S Power Supply Build Doc-1.0a.pdf
Hi all! Please help me how to check AD1862N for serviceability. On AA DDE 3.0 DAC suddenly lost sound. With power off DAC and USB-transport board, I2S cable was bitten off with the help of cutters, then a jumper from pin 22 to pin 19 was thrown to the HDCD filter PMD-100 (to disable an attenuator). Then the DAC was turned on and found out that there is no sound in both channels on Coax, Toslink and I2S (all of inputs). All voltages on the board are normal, the Lock indicator lights up, and when turning on a stream with HDCD signature the indicator also lights up on the input that is connected to the specific source. I found information on how to check DAC chips for serviceability by measuring resistances between certain pins. I measured resistances on the extracted chips - everything turned out to be normal. But when the DAC for some reason there is no signal on the (analog) oscilloscope on pin11 (lout). On pin 7 (from the digital filter) the signal comes (even pulses are visible). Help me, please!
I ran I2S over HDMI to an Ian Canada HDMI receiver, and from there to the shift registers on the 1865 board. It was nowhere close to I2Sover USB bypassing the shift registers. I imagine the lack of reclocking by the HDMI receiver was the bottle neck, which could be overcome with more of Ian's gear. I do use the external oscillator board with the I2SoverUSB, and still this is more cost effective than Ian's FIFO reclocking options. The streamer was a Magna Mano Ultra-III which bested the Denefrips Hermes DDC in my system, with another brand name DAC. I am a complete USB convert.
It's all very similar. The PCM63P-Y gives the brightest sound so you need to choose your I/V opamp carefully. We will see the result with some tubes, it will be something completely different.
I do not know. Very strange chip. When I listen to it, I have the impression that all the tracks play faster than on others. It does NOT forgive if the recording is bad or if the sound designer and production is not top-notch. The brain struggles to process the amount of information coming out of it. It is not for everyone's ears. Especially for the 'basshead' listener/preference in music. Or who likes soft and warm reproduction. Maybe it can be compensated with a dedicated opamp, but then the sound of the opamp becomes dominant.
