Best Compression Drivers today 2022?
- I've never "heard" the pretty obvious ( on paper ) HF - UHF breakups up top ( though my hearing above 12K is MIA ).
- FWIW, any time that I've listened to this driver I never thought that I was listening to the "dreaded" titanium sound ( which I suppose is a bit of a back-wards compliment ).
Same here. But a little bit of neat sparkling in the UHF does remind us that we are listening to music through a system set-up for HIFI, whilst retaining the benefits of moving a lot of air thanks to the large radiating areas (presence, impact, realism etc).
Reactions: GM and EarlK
They do not fit the same JBL waveguides/horns as the 2450/51/52/53 due to the differences in diaphragm design and phase plug, deeper backchambers on older drivers etc., not counting 3" vs 4" even.
Why??? I have used 2435's and 2453's on the same waveguide?? They fit just fine. Have used 435Be vs 476Mg on the M2 fit just fine. The 2451 has a different larger bolt pattern. The 2450SL 52 and 52 all the same.
Rob 🙂
Compared how?
None of them have the same exit angles, throats, falre rate etc.
So none of them will really fit the same horn/waveguide, and give optimal results for more then one of the drivers at best. EQ can't really fix reflections, diffraction, HOM's etc.
As mentioned in the review of the 18Sound ND1480be, Crowe said that he used his ES600 horn
https://josephcrowe.com/products/es-600-bi-radial-wood-horn-no-1978
Following the measurements, Crowe also gives his listening impressions of this driver/horn combination.
For the Radian 745neobe, Dickason also ran and posted all of the same measurements, using the B&C ME90 horn, though he apparently ran no listening tests.
Actually, I was rather foolishly hoping that you might have heard both of those beryllium drivers-used with suitable horns and adapters-and therefore could offer your own comparative impressions of how they sound.
I should probably have wrote that it is'nt a ideal match or something to be more clear. Sorry for any misunderstanding🙂
As for fitting physically, with bolt patterns, and phaseplug exiting at the throat etc. same as other JBL designs yes.
I suspect you know the 2435/435 way more intimately then me, as you were involved in a lot of the discussion on LH forums.
They tend to have some quirks on the PT waveguides, M2 etc.
The 2435H is finicky as to what wave guides it works with because the phasing plug is so short. - Courtesy of Doug Button - JBL
Reactions: Robh3606
Interesting discussion. Particularly for me the Beryllium discussions.
I've not tried many compression drivers..
I do however prefer my refurbished (by Vitavox in Bristol ) Vitavox S2s sound to the JBL2435Bes, I also had. Both are 1.5" exit.
No idea why technically 😀
I find the S2s better tonally and they sound faster on complex fast music (Vivaldi violin strings for example).
Have to use the S2s right, and either EQ the 1.7 to 1.9KHz bump, or cross it away (3uF cap method).
It's unfortunate that beryllium drivers are expensive, otherwise there would likely be more feedback about them at threads like this. I've never heard them either and only know of one longtime user who's highly pleased with them, especially with high res source material. He attributes his lasting happiness with the Radian 745neobe (no hardness, fatigue or analytical sound; just "clean") to his perfecting of the required EQ for extending the HF response of that two-way system (TAD 15" woofers in sealed cabinets). He also designed and built the throat adapters for the Athos 4001 horns.
I'd be very interested in your comments on these drivers and how they were reviewed here
https://audioxpress.com/article/the-745neobe-compression-driver-from-radian-audio
https://josephcrowe.com/blogs/news/18sound-nd1480be-beryllium-1-40-compression-driver-test-review
Properly EQed, would you suspect their performance to be nearly identical?
If not, how would they differ, and by how much?
This is not easy to answer at all. One should have access to both and measure them in the same horn, with the same equipment and settings. By the available curves one can suspect the Radian of having more small resonances, but phase plug geometry affects the performance a lot, and this it not revealed by these measurements. The output level at high frequencies is very low for the Radian. It may be a poor fit to that horn, but I have not gone into detail to check that. If the exit angle of the Radian is higher than the entry angle of the horn, one can get a suckout in the response. But as I have worked with the 1480Be, I can say that it is a pretty good driver.
when you say "hype" I am not sure just what you mean? are you suggesting that Be is not a significant improvement over say aluminum diaphragms? clearly being able to push up first resonant modes is a big step forward. I would like to see further research into suspension design/materials and into diaphragm coatings.
I realize my post can be easily misunderstood.
There are three main points that to my opinion should be highlighted:
- Firstly, a pair of 1 inch domes typically contains a couple of Euro worth of diaphragm material. The process of making them is similar to that of making aluminium or titanium domes. I see no reason why every Be dome should be priced several hundred Euro over their aluminium or titanium counterparts.
- Secondly, in some cases, there are other metal domes that perform at least at the same level as their beryllium counterpart. One great example is the Bliesma T34A vs the T34B. Still people go for the beryllium version without hesitation. Some have even described the sound difference. It is like a copy-paste of any other beryllium vs anything else-review. It is like people struggle to listen past the material. A bit like when people are unable to un-hear the "metallic sound" of a metal dome, while the flawed dispersion pattern of a soft dome just gives "soft sound".
- When people test beryllium compression drivers, even 4 inch drivers, where the main break up is well within the audible range, people describes them as having "the same sound as beryllium domes", while small beryllium domes do not ring in within the audible range. They do not have the same type of sound.
So by "hype" I do not mean that beryllium is not a very good material for domes, but unfortunately it is hyped in such a way that many people struggle to judge the sound objectively. It is extremely over priced and at the same time, it is not a free ticket to great sound. But beryllium seems to be a kind of "wow, it is beryllium, I can hear that, it is great, like all beryllium." Just like if all aluminium diaphragms, regardless of shape, size and usage, should sound the same.
